Question about Poulan Garden
No gas to carburetor will not start - Poulan Garden
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
  • Jim Parker
    Jim Parker Jun 24, 2009
    Did this solution solve the problem?
    Jim
I have a toro super cycler gts 5 model 20475 6.0 engine i put new gas in it a new spark plug but if i loosen the gas bowl no gas come out and it wont start what could be wrong
Ensure fresh gas is in tank. Follow gas line from tank to carb. Have locking pliers ready to pinch off gas line or close gas line valve. Remove gas line from carb. observe gas flow to carb. Remove carb bowl from bottom of carb. Attach gas line to carb. Does gas flow to carb. Observe float, float down gas flows, float up no gas flow. If float is bad replace float assembly or carb. Remove float mounting pin and needle metering valve. Use a bread wrapper pealed back an inch so thin wire can clean out port of meter needle. Use wire to clean out center port. Observe bowl screw look for hole thru screw, clean out with wire if preset. Re-assemble carb. Clean replace air filter. Fill oil. 30w. Prime motor, pull rope 10 times to start. No start, replace carb.
Aug 02, 2013 | Snapper 20 HP Lawn Tractor 2690578
My gmc jimmy truck starts with starting fluid then stopS
sounds like no gas getting to the carb. plugged fuel filter, fuel line, bad fuel pump. the carb should squirt a little gas when the throttle is pumped. leave ignition off while looking down the carb and pump the throttle linkage to visually check that gas is squirting down the carb with each stroke of the linkage. maybe you are just out of gas!!
Aug 25, 2012 | 1997 GMC Jimmy
I have a briggs and straton 3750 portable generator. it had be sitting in the garage for a year and a half with gas in it and the full switch on. i needed it a couple of days ago and it would not start. ...
Spraying carb cleaner into the carb doesn't clear the gummed gas that is clogging the supply of gas to the carb. Remove all of the gas. Put a little fresh gas and carb cleaner (about 50/50) in the tank. Try to get that to run (spray more carb cleaner or instant start into the carb to help it start - you might have to do that a couple of times). If it does start, let it run out of gas then refill the tank. If that doesn't work remove the bowl from the carb and clean the float valve and the mixture valve.
Good luck, Al K
Jan 31, 2011 | Briggs & Stratton Electrical Supplies
Will not start, put new gas in it, stabile in gas, new sparkplug, dry gas in gas. Gas left in it over the summer months, so I sprayed some carb cleaner in carb. It just turns over. Drained gas from bulb,...
It is very common for the jets to varnish up (even with StaBil) and carb cleaner can't get into those areas. You can take the carb off and soak it in carb cleaner.
One method that I try before I take it apart is to spray a ONE second blast of starting fluid into the carb throat. Attempt to start the engine. If everything but gas is ok, the engine will start. Do it only one more time, this time with the choke on full and usually this is enough to get the engine running.
Be careful and don't do this more than twice. Starting fluid is very dangerous to use and will ruin your engine if you use more than a one second blast more than two or three times.
Have a fire extinguisher handy if you motor backfires and the carb throws a flame.
Jan 13, 2011 | Garden
I have a problem starting my Toro Power Max 828 LE snow blower. It has fresh gas and a new spark plug. When you prime it it doesn't seem to be getting gas. It also has an electric start that is working...
Take a spray bottle and spray gas into the carb and see if it starts.If it starts you more than likely have a carb problem. first thing check and make sure gas is flowing to carb. Take the line off at the carb and see if gas flows through the line. If you have gas to the carb you will have to take carb off and clean it out and check to see if float is stuck closed.you might want to put a rebuild kit in it while it,s apart.
Dec 17, 2010 | Toro Garden
My hedge trimmer will not start... Put in new gas
It's not getting gas, due to being gummed up with old gas. Remove all of the old gas and mix up a batch of fresh gas&oil. Also get some carb cleaner. Put just a little of the gas&oil mix plus an equal part carb cleaner. Try to start it just to work the new mixture through the carb. You might use the spray start to help pull the new gas through. If it fires up on the new gas&oil&carbcleaner mix, shut it off and let it sit for an hour or two. Drain it out and try just a little gas&oiil without the carb cleaner. If all is well fill the tank. If not, repeat the whole process. If you can't clear the gum this way you may have to remove the carb to clean it. Good luck.
Oct 22, 2010 | Craftsman 22" Gas Hedge Trimmer
Jet pulse carb will not feed gas to engine after start
Make sure the gaskets were installed correctly.
Oct 08, 2009 | Garden
Try to start my 95 dodge dakota and it won't start
dont take carb off, drain fuel from tank if you got bad gas, fill with good gas, pull fuel line off carb and turn on key if have electric fuel pump, this will clean out line. get a spray can of carb cleaner from auto store and spray carb. hook up fuel line and try to start, should clean out carb with fresh fuel
Dec 31, 2008 | 1995 Dodge Dakota
Needle and seat are stuck closed
drain the old gas out put some new gas in the tank and turn the fuel petcock to PRI or ON and check that there is a flow of clean gas to the carbs. Tanks that are badly rusted will require a filter in the gas line to the carbs. If not see the Gas Tank Page. If the gas starts to come out the carb over flow tube(s) tap the carbs gently but sharply with a plastic hammer or the plastic end of a screwdriver. Do this to each carb several times or until the gas over flow stops. If it does not stop you will have to take the carbs apart and find out why the fuel valve (needle and seat) is not working. See the Carb page. If it will not start, try to drain the fuel out of the carb with the float bowel drain screw. If nothing comes out, nothing is going in ! In other words the needle and seat are stuck closed. Again, if tapping the carb doesn't start the gas flow, take the carb apart to find out wh,,,
Nov 10, 2008 | 2000 Alfer VR 2000 Supermoto
Garden Logo
111 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
