Video card? Last week my monitor went blank. I hit the reboot buttom and it came back. It eventually got to the point it would not come back. I swapped it out for another monitor. This monitor is doing something similar...going blank, going white, odd graphics. If I reboot the system, it comes back fine and works until I leave the machine. Come to think of it, it works until it goes into "sleep mode". Then it messes up.Is this the video card or something else? Running Windows XP on a machine about 4 years old. Thanks!!
  • 2 more comments
  • wadow Nov 04, 2007
    Same thing is happening to me. I had it for a little while then my monitor went blank. Took the graphics card out put it back in then it worked. BUT to find a day later it did the same thing. Tried a new monitor nothing. Put it in a different computer it worked for 2 days then bam same thing.
  • Anonymous Mar 30, 2008
    I have the same problem with my Nvidia 5700LE on P4P800-X mainboard.
  • Anonymous Oct 15, 2008
    my video produc it not function
  • nikhilkudyar May 11, 2010
    My moniter went blank.its 915 gav.i ve no graphic it my video card is faulty or it can be solved by using graphic had also happened earlier.then i replaced it as it was under warranty.but now i cant as its warranty has me out.
The same happens to me, I have vp880 pro running in a windows xp. When I reboot the sistem when the first Windows xp 32 bits screen appears if I open the dvd unit and close inmediatle then the sistem always works and the screen appears normally. Anybody have a better solution for this?
Thank you
Posted on Nov 02, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
What graphics card are you running?
and what system do you have?
Posted on Nov 02, 2007
Monitor is changing colors and won't wake up
This problem should not be only with your monitor, but also with your video card. You might have left one image sitting for long hours. There is no specific solution, but for Lcd users, you can try this. Leave the monitor off for few hours without any connection, maybe power chord or vga/dvi/hdmi cable. If this doesn't fix then the problem must be from your video card. You can try the monitor on another system to make sure, which one is the culprit. Your last choice is to reset the bios, to do this, remove the bios battery and leave it for few minutes outside (2 mins will do) and put it back. Reboot your system, this will fix your problem. Good luck. Thanks for using FixYa.
May 31, 2010 | ViewSonic VA721 17" LCD Monitor
Dell 1800fp dead
Each monitor has a different response to "no activity" from the system. So for the monitor, if you get a chance, try your monitor on another machine that you know does function. At work, neighbour, or other.
For the computer, does the it (beep) or POST (Power On Selft Test) when you turn it on, do you see and hear what you would if the monitor was connected?
If it sounds normal, then everything should be fine and luck might have it, your backup monitor is not working either, try another one from the same friend or neighbour above.
If it doesn't POST, you could have a video or other card or ribbon connection loose in the computer. Either you or a friend, or the service center, whichever feels comfortable reseating all the external and internal equipment, bearing in mind static electricity and proper handling measures for the computer.
Nov 26, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Have HP slimline series. Came back from a break.
Try another monitor on it to verify it is the video card that has gone bad. If it does not work with another monitor then that is the likely culprit.
May 06, 2010 | Computers & Internet
Boot performance monitoring error
>> Tired to reboot several times and still no video.
>> Waited until the next day and the video was working.
>> Very strange.
Sounds like overheating, either inside the monitor, or on the video-card, or inside the computer.
When it happens again, disconnect the data-cable from monitor from the desktop computer, and connect the data-cable to a laptop computer.
If the monitor works, then it's not the monitor that is the problem.
Also, when it happens again, have another monitor, and connect it, to see if the other monitor works, or if the video-card cannot "drive" either monitor.
Apr 05, 2010 | Computers & Internet
Monitor not displaying
our video driver probably was updated. You can try rebooting the PC hitting F8 and going to "Last Known Good Configuration" You can also try running a system restore to rollback to before you were having the issue. Finally you can reboot hit F8 boot into safe mode, go to control panel and system, go into the device manager double-click on the video card driver and roll it back to the previous version.
I do not think it is the monitor's connection since you would have not initially seen the Window's splash screen.
Jan 11, 2009 | Dell E176FPC 17" TFT LCD Flat Panel...
Monitor screen ia blank
open it and see if you can find a blow capacitor on the logical lcd´s very common to happen in this kind of model...
Good Luck!
Dec 04, 2008 | Gateway FPD2275W LCD Monitor
uninstall ALL video drivers reboot computer should reboot with standard windows video drivers does the screen still play up if so you may have faulty video card.let me know please
Jul 17, 2008 | ATI Mobility RADEON Graphic Card
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
