Remove to clean - Heating & Cooling
  • sajbo4 Jun 20, 2009
    This is a wall mounted a/c. I have the front panel off, but can not remove it from the mounted casing. I belive there is a screw/bolt that needs to be removed, but can not find it.
  • 334 Answers
It is probably on a hinge, what exactly are you trying to do and what kind of unit do you have. Make and model
Posted on Jun 20, 2009
  • seth veloso Jun 20, 2009
    If you are just trying to clean the filters, they slide out the top. If you are pulling the entire front off, there are usually some posts that it will slide off of in the bottom corners
    Scholar:
  • 174 Answers
Here you go for all your answers:
http://catalog2.panasonic.com/webapp/wcs/stores/wwwconsumer/customersupport/faq_airconditioners.jsp?storeId=&modelNo=
http://searchwarp.com/swa8098.htm
gud luck.
saumya.
How to clean Metal Filing Cabinets?
Metal filing cabinets are tricky to clean. Start by cleaning the exterior of the cabinet. Use clean water to clean the outer side with sponge. Remove the rust by applying navel jelly on them and remove it completely by clean cloth. Use fine sandpaper to remove the flakes and mineral spirits to get rid of the dust. At last paint the metal cabinet by spray paint or liquid paint.
Visit Fire Cabinets Direct Ireland for buying fireproof cabinets & chubb cabinets in online..
Mar 05, 2016 | Home Security
Tip
How to Clean a Solenoid Starter in car?
1) Keep the starter on a clean surface.
2) Clean the starter with lubricant cleaner.
3) Remove the motor from starter by removing the bolts holding the starter.
4) Clean the bolts also with the lubricant cleaner.
5)After the bolts are removed the stater will come out.
the inner cylinder connected to the starter will not come out.it will remain in place.
6) Properly clean all the components with lubricant cleaner.
7) Use cleaning brush and rag to clean all the inner components.
8) The starter is cleaned now.
8) Then reassemble all the components back.
This will help.Thanks.
on Mar 18, 2010 | Daewoo Lanos Cars & Trucks
Tip
How to Clean a Solenoid Starter in Acura integra car?
on Mar 18, 2010 | Acura Integra Cars & Trucks
When I try to use the self-clean program, I remove the racks but then the cleaning cycle won't start and the "remove racks" indicator is flashing. There is a vertical metal piece in the back of...
I just did the self clean function today. They need you to remove the rack supports from each side of the oven cavity. Simply pull up on them to remove. When I did this the message was not displayed and the slef clean function started. Hope that helps.
Darren
Nov 15, 2010 | Electrolux 30" Self-Cleaning Freestanding...
How do i clean my cooktop on a whirlpool 465
Light Cleaning
  • Clean your CERAN cooktop after every use. To remove simple spills, wait for the surface to cool before beginning the cleaning process. Pour a small amount of cleaning cream on a damp paper towel and wipe the cooktop surface until the soil and cream are no longer visible. The cleaning cream will leave a protective finish, which will preclude scratches and other types of damage.
  • Heavy Cleaning
  • Wear a heavy oven mitt to remove burnt foods or liquids while the cooktop is still warm. Use the metal razor scraper to remove the substances that are stuck to the cooktop surface. Once the cooktop has cooled, use a damp paper towel to spread a small amount of cleaning cream over the entire cooktop surface and wipe it thoroughly until the cream is no longer visible. Rinse the cooktop with water and dry with a clean paper towel.
  • Cleaning Melted Substances
  • Remove melted plastic, foil or other kitchen products immediately using the metal razor scraper. Spills containing sugar, such as ketchup, tomato sauce, syrup or pudding, must also be removed with the metal scraper at once. It is best to remove these substances while the burner is still hot. Once the melted substance has been removed and the cooktop has cooled, use a damp paper towel and cleaning cream to complete the cleaning process. To protect your hands, remember to wear a thick oven mitt when cleaning the hot cooktop.
  • Tips
  • Scratch marks resulting from daily use will not interfere with the performance of your cooktop. Pots and pans with flat bottoms and those that cover the entire burner surface are recommended for use on your CERAN cooktop.
  • Warnings
  • Spills containing sugar may permanently damage your cooktop unless the substance is removed immediately. Use only the recommended cleaning products on your CERAN cooktop to protect it from damage. Do not use scouring pads, plastic coated sponges or abrasive products of any type. Do not use oven spray or any other type of cleaner containing ammonia or chlorine. Clean all spills thoroughly before using your cooktop again.
  • Nov 07, 2010 | Whirlpool Cooktops
    The inside of my fan looks very dirty and I would like to take it apart to clean. Do you have any instructions on how to do that?
    #1 CLEAN WORK SPACE
    #2 PLACE FAN ON ITS CONTROL SIDE DOWN
    #3 REMOVE PHILLIPS HEAD SCREW FROM HANDLE
    #4 REMOVE NON-SKID COVERS
    #5 REMOVE OTHER 2 PHILLIPS HEAD SCREWS
    #6 REMOVE BLACK SIDE & CLEAN
    #7 REMOVE YELLOW FAN COVER & CLEAN
    #8 7/16 SPIN-TYPE DRIVER REMOVES FAN NUT
    #9 CARE....WASHER ON OTHER SIDE OF FAN
    #10 PUT FAN IN SOAP& WATER ....TAKE YOUR TIME
    Oct 14, 2010 | Lasko 655702 Stanley Blower Floor / Box...
    I do not know how to clean it. It is called Fresh
    The Fresh Air has a reminder on the LCD to Perform Cleaning. This reminder will display if the purifier runs for 30 days. When this reminder is displayed perform the following steps to clean your purifier.
    1. Cleaning the Case:
    Wipe the unit with a soft cloth dampened with water. Do not use chemicals or solvents. Vacuum the front and rear grills to remove any lint buildup.
    2. To clean the lint screen, RCI cell and purification plate:
    3. To remove the back cover:
    Remove the plug from the back of the unit. Unscrew the screw above the plug socket on the back cover. To remove the back cover, press the back sides of the back cover to unlatch and tilt the bottom of the back cover to remove.
    4. To remove the rear lint screen:
    Remove the two thumbscrews holding the top of the lint screen. Remove the lint screen by pulling back the top of the screen, then lift it up and out.
    5. Removing the RCI cell:
    Remove the RCI cell connector by pressing the connector locking tabs. Pull the connector straight out to unplug.
    Remove the RCI cell by removing the two thumbscrews. Slide the RCI cell down and out of the unit.
    6. Cleaning the RCI Cell:
    Remove the RCI cell and carefully vacuum accumulated lint. Do not wash the RCI cell. Damage from water may result.
    7. Rear lint screen cleaning:
    You have two options
    1. When visibly dirty, simply remove the rear lint screen from the unit and with a duster attachment on a vacuum, remove the heavy particulate.
    2. In addition to step 1, the filter can be washed with hot water (do not use soap). Allow to dry prior to reinstalling. Replace if damaged.
    8. Cleaning the Purifier Plate:
    Remove the plate from the card cage by grasping the middle edge nearest to you, and slowly pull it straight out. Clean with mixture of one part water and one part ammonia. Place plate and ammonia mixture in a dish and allow it to soak for no more than 10 minutes. Remove plate and scrub with a toothbrush. Rinse thoroughly and air dry for 24 hours or use a blow dryer to dry thoroughly.
    After all parts have been cleaned and are thoroughly dry, reinstall components in reverse order. Turn the purifier on, and on the key pad, press the reminder Reset button to clear the Perform Cleaning message.
    If this has been helpful, please rate this solution. Thanks
    Jan 28, 2010 | Ecoquest Fresh Air Living Air Purifier
    How can remove inyectors easy way to clean suzuki
    Hi There, You don't need to remove the injectors to clean. Just add BG can of BK44 to the gas tank. That will help clean them or go somewhere and have the fuel injection service clean done. These injectors don't give problems. Don
    Oct 07, 2009 | 1999 Suzuki Grand Vitara
    Kenmore Quiet3 not cleaning top rack, now stopped cleaning all
    The problem is likely that the cutter/chopper filter is plugged. This reduces or eliminates water flow to the cleaning arms.
    Solution:
    Remove dish baskets
    Remove bottom arm - Rotate the centre post until arm is free to be lifted out.
    Remove conduit to top arm(s) - Remove 2 screws, one at top and one at back. Rotate whole conduit 45 deg right and lift off of centre post.
    Remove bottom plastic assembly. - Remove 4 screws and lift off.
    Remove cutter cap. - Remove 1 screw at front left. Lift off plastic cap. Remove cutter filter. It is on a spring loaded pin. Pull cutter blade foreword and lift filter disc straight up. Clean filter disc thoroughly
    Reassemble!
    Dec 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
    Clean vent
    The vent (also known as grill assembly in GE literature) comes off after removing the two screws at the top of the unit and gently sliding the entire assembly to the left about an inch. This will allow the vent to be cleaned of grease, hair, etc., as well as giving some access to the areas behind the vent.
    Dec 21, 2007 | Microwave Ovens
    Heating & Cooling Logo
    Top Heating & Cooling Experts
    Paul Carew
    Tim Whalen
    Marvin
    Marvin
