Question about Linksys Wireless-G WRT54G Router
Router says connected but I can't access the internet
My router was working fine. I unplugged it & it hasn't worked since. Does the local area connection have to be enabled. Is it correct that if i can't connect to the local area connection that the router wouldn't work?
  • 2 more comments
  • Anonymous Nov 03, 2007
    I plugged everything in and tried to get on line. when I am connected to the internet through the router I cannot find the server. I talked to lynksys and followed their directions but to no avail. the computer says everything is hooked up and working fine. I have a laptop and it shows a strong signal but says a cable is unplugged. Need Help
  • Anonymous Nov 04, 2007
    power led is blinking. cannot access to
  • Anonymous Jan 06, 2008
    i hooke dsl modem and wireless router ,but the inter will not connect,change back to mmodem only ,the internet works,did what the cd said. i fell that the wrong user name for my internet was put in ,but i don`t know how to change it or where to
  • Anonymous Dec 06, 2008
    I have a linksys WRT54G2 wireless-G, which was working fine when I first set it up with factory default SSID & password. But later I went back and changed the SSID & password, made the network secure, and then (what was probably the big mistake) unplugged the power supply cable from the router (as a means of turning it off). After that, I not only couldn't access the internet from my wireless laptop, but I could no longer access it on the master desktop to which the router was connected.
    I can see the network listed, I can "connect", but when the browser comes up, it "can't find the page". On the desktop, I just get a big blank space in the browser. And both connect very slowly, despite an apparently strong signal.
    I've tried powering everything down & starting up modem, router & PC, but nothing's changed.
Can get on to internet with my computer
Posted on Sep 24, 2010
  • 143 Answers
Ok... I see two people here with what appears to be the same issue, however "Guest" seems to have a more specific problem. I want to clear that up first.
To "Guest":
You are confusing your ETHERNET (Wired) connection with the Wireless connection. If it says that "a cable is unplugged" then it is refering to your ETHERNET connection. (Also known as "Local Area Connection" by default.) If you are not going to be connecting your laptop to the router by way of an ethernet cable, then you can actually disable that ethernet port by right-clicking it in the "Network Connections" window and selecting "Disable". (This is how it is done in Windows XP. Windows Vista is a little trickier for some reason.)
If you are showing a strong signal after that, it means that your Wireless adapter is still working correctly. Make a new attempt at connecting to the wireless router by finding the name of your router in the list of available wireless connections and clicking Connect.
If your router's SSID (name) does not show up in that list, then it may be secured as per the default settings. The newer models of the WRT54G router have a button on the front that you can press to temporarily disable wireless security so that you can log onto the router and make your settings. Look on the front of your router for the "CISCO" logo near the front-left. It is illuminated by an orange glow. This is to enable SES or "Secure Easy Setup".
Pressing this button will turn it white and it will probably blink, too. While this light is white, you should be able to find the router on the list. But it will be called something different. It should have random numbers and letters as the router's ID and should show a fairly strong signal.
This is a temporary connection. This gives you enough time to log on to the router and change it's settings before the open connection times out.
To make all of this as easy as possible, I would make sure to do two things:
1.) Use the RESET button on the router to set it back to factory defaults.
2.) Make sure you unplug your cable modem and plug it back in before reconnecting it to your router.
3.) Make sure that you leave all default settings for all network adapters in Windows.
4.) If you have connected your laptop to other wireless networks called "linksys" in the past, it may have the settings of those previous routers in the history that Windows keeps for all wireless connections. You can find that list and CLEAR IT by right-clicking the little icon in the lower-right corner of your Windows task bar and selecting "Open Available Wireless Networks" and finding the list on the left side of the next screen.
I can't advise on much beyond that until I know the results of this procedure. But it sounds like both of you are having the same issue. Here's a tip:
For now, ignore ANYTHING that says, "Local Area Connection". That has NOTHING to do with wireless. That is the WIRED connection. (Ethernet.)
I'll watch here.
Posted on Nov 04, 2007
  • Cory Kielion
    Cory Kielion Nov 08, 2007
    I take it that you were able to connect to your router. Congrats. :)
    If you can't be more specific and eloquent than that, you have no business being here trying to give any kind of support.
    It is also VERY bad etiquette to beg for a rating the way you did.
    Please don't do that anymore. That alone is good enough reason to give
    you the LOWEST possible rating.
    These people are coming here to get help. Not give you good marks that you clearly don't deserve.
  • 193 Answers
Not like that u dont need to enable local area conn>and correct all teh pysical conn>and reboot the devices and also the pc>rate me solved if its help full
Posted on Nov 03, 2007
I have d-link DIR600 router. When i am using my ethrnet cable to my pc it is working fine but when i am trying to use it with DIR 600 router it is not even detect internet connection
Most likely the cable modem is currently locked on the MAC address of the PC. Try the following:
  1. Power off the system, the power off the router (Unplug Power connection) and Unplug the Cable Modem power connection.
  2. Wait 3 minutes
  3. Power on the cable modem and let it completely reset.
  4. Power on the Router, making sure the cable modem is connected to the UPLINK port of the Router.
  5. Power on the system, making sure it is connected to any of ports 1 through 4
  6. Normally, this will resolve.
If issue persists, Right click the local area connection and Click REPAIR
Jun 20, 2011 | D-Link DIR-600 Router
My router was working fine until my mum unplugged it to move furniture then plugged it back in. now I can connect to local network but no internet access, I think it is something to do with ipv6 and I have...
Try to unplug both power cords from modem and router. Wait for 10 seconds and plug in your modem first. Wait 1 minute to make sure the modem find a new ip address and then plug in your router. You should be able to get your internet back this way. If it doesn't work after that, try to restart your computer because it probably keeps the old ip address until you reboot.
Hope it helps!
Feb 08, 2011 | Linksys WAG200G Router
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    My router is shutting off my internet
    There are a few things that can cause you to lose wireless connection with your wireless router.
    1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible move the wireless router higher up.
    2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
    3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
    4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
    Sep 28, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Can't connect to internet on desktop computer
    Most likey the issue is with the network adapter. As it does not work even with the modem and router the card seems to be faulty.
    Hope this helps.
    Sep 05, 2009 | Computers & Internet
    Cannot connect to the internet with usr8054 and speedstream5200
    first, make sure that cables are properly seated between the phone jack and to your modem, between modem to your router, and between router to your computer
    second, access the software for your router
    third, configure the wireless settings for your computer and to your router
    fourth, check if your wireless settings is configured by disabling the Local Area Connection
    if successful unplugged the cable connecting your router to your computer
    if unsuccessful please inform me immediately.
    Feb 23, 2009 | U.S. Robotics USR8054 Wireless Router
    Dlink DI-614 router wont stay online!
    I would start with the simple things first:
    1) reseast the ethernet cables
    2) change the ethernet cable
    3) change to different port on the router
    4) uninstall/reinstall drivers
    5) run spyware cleaner and anti-virus
    Feb 15, 2009 | D-Link AirPlus DI-614+ Wireless Router
    "Local Access Only"
    You need to look on the back of your router and find the small reset button. Push it and everything should reconfigure. If not Go into your device manager and see if you can find something called a NIC card or Network Interface Card, or something called an Ethernet card, if those are not listed, it means your driver has been deleted somehow. You can go to the manufacturers website and download a new driver.
    Sep 22, 2008 | Linksys WRT55AG Router
    Local area connection
    If it says that your local area connection is unplugged then you cant have a cable plugged into the ethernet socket on your pc into a router or there is a break in the cable.
    Feb 10, 2008 | NetGear WGT624 Wireless Router
    Linksys Wireless-G WRT54G Router Logo
    1,535 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
