Question about HP Officejet Pro L7680 All-In-One Printer
Paper jam I have an HP Officejet Pro L7680 All in One. I have been using it primarily to make copies, app.500 copies per week for app. 2 years. We use the "fast" quality to make copies. Now the paper does not get picked up correctly, and it jams frequently. It will pick up several pieces of paper at a time. I have cleaned all the parts that I could reach, and I have inspected to get any torn or loose pieces of paper out of the machine. I have changed to "normal" quality print. This helps only marginally. The paper still either won't get picked up or multiple pieces of paper get picked up. The machine makes a grinding noise when operating.
  • HP Master
  • 365 Answers
Call HP and replace unit under warranty.
Posted on Jun 20, 2009
Paperjam on mx360 conon
Switch off turn to access the rear, release catches backing will drop access to rear, remover paper if there, alternative on top where you feed paper for faxing or copying lift item may find a paper jam there, be careful when removing from either compartment
Nov 01, 2013 | HP Officejet Pro L7680 All-In-One Printer
Hp office jet l7680, paper jam, however no visible paper remaining, jam indicator still flashing.
If the printer shows ready and after you send the print or copy job it gives you paper jam, then the problem is with the pickup roller.
Let me know and I will help you further.
Oct 13, 2011 | HP Officejet Pro L7680 All-In-One Printer
Our HP L7680 keeps telling us there is a paper jam...and there for will not let us copy etc. There is no papaer jam?
Unplug the power, open up all the covers and make sure there are no foreign objects (even small peices of ripped paper).
Close everthing up and power on.
If the message persists, there is a sensor problem
Mar 24, 2010 | HP Officejet Pro L7680 All-In-One Printer
My printer is jammed.It is an HP officejet pro L7680 All-in-one
Hi! I will be glad to assist you in this issue. her eis the link for the solution:
If its a paper jam.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00839319&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512009
if its a carriage jam.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01389539&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512009
Nov 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7800. Had paper jam, but opened
mine was 2 there was paper stuck in the little white gears
Nov 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
When trying to use the scanner to make a copy of a document. The paper jammed, how do you remove it? It said on the glass window to remove the back where the ink containers are. I did that but I cannot see...
There are possible 2 places for the paper jam, either the Feeder has jammed or from the input tray.
For Feeder, you just have to open the feeder from the top and see if there are any pieces sticking in.
Else, you can open the print head cover and look for pieces of paper jammed in it.
Another place you may see is by removing the rear of the printer, it is called a duplexor which can be taken off easily. You may find some bits of pieces in rear of the printer.
To avoid getting another jam, try to keep the paper in a cool and dry place. If the paper absorbs any humidity, it starts crumpling which results in paper jam. You can also try fanning the papers before putting in a bunch and use a recommended paper for the printer.
Hope this helps.
Cheers...
Oct 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
I need help removing a paper jam in the document feeder on a hp officejet pro l7680 all in one
Hi. here is the link to HP and what they recommend. I hope it solves your problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00839319&lc=en&cc=us&dlc=en&product=2512009
Aug 05, 2009 | HP Officejet Pro L7680 All-In-One Printer
Paper jam hp officejet pro l7680
The full instructions are located here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00839319&lc=en&dlc=en&cc=us&lang=en&rule=29041&product=2512009
The section you need is about halfway down the page (Step 6: Clearing the ADF)
Apr 09, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejst Pro L7680 All in one
Printer gives repeated "clear paper jam" messages and even though there is no paper anywhere in the paper path it will not clear.
Oct 10, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
204 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
