Question about Frigidaire Affinity ATF7000ES Front Load Washer
Need to take front off
Need to replace the pump
    Sniper:
  • 68 Answers
On the affinity washers, tou acess the pump from the back. there is a large service panel that is removed by a couple screws. the pump is right there for you to work on. shane
Posted on Jun 24, 2009
Hello,my 2000 odyssey leaks oil.guy said its front oil seal but im gonna need time belt,water pump,vtec valve and oil pan gasket.Do i really need all that just to change front seal? $400 for labor?
A leaking front seal will allow oil to get into the area where the timing belt is located. This will cause oil to get on the belt and can cause damage. Since the timing cover must be removed to access the front seal, it is recommended to replace the belt while you are in there. Also, the water pump is driven off the timing belt. Replacement of the water pump is always recommended when replacing the timing belt for two reasons. First, it is easily replaced at this time and it is good preventive maintenance. Secondly, the water pump bearing is under tension from the timing belt and develops a wear pattern. Replacement of the belt without replacing the pump will cause the new belt to wear the bearing in a different pattern, often causing leaking in a very short time after the replacement. This would then result in having to repeat all the labor again to replace the pump. It is easy to see that for $400.00 labor, you don't want to do that again in only 2-3 months. as far as the VTEC valve is concerned, I don't see a relationship to the oil leak. It could just be something else the mechanic found during the inspection. I can find nothing in the remove/replace procedures that requires replacement of the oil pan gasket. Again, maybe something additional that is needed from visual inspection, but not needed for the front seal.
Apr 03, 2016 | 2000 Honda Odyssey
How to change a front bearing on sp 1540 c pump
you cannot they dont sell bearings get number of pump and motor you will have to replace the motor if you can get it make sure to get the seals
Aug 03, 2014 | Hayward Pool & Spa
Need instructions for replacing my window washer pump on my '06 hyundai sonata, please?
You'll need to remove the two retainers from the front portion of the right front fender liner. Then pull the front portion away from the bumper cover and fender to expose the washer pump. To remove the pump, simply unplug it and pull out of the washer bottle.
If you have less than 60,000 miles on the car, I'd recommend taking it to the dealer for warranty service
Jun 14, 2012 | Cars & Trucks
I need to replace oil pump on a 1988 ford bronco 2
Remove oil pan, making sure to drain oil first. Remove oil pump attaching bolts. Lift off oil pump and withdraw oil pump drive shaft.
INSTALLATION;
Prime the new oil pump by filling either the inlet or outlet port with engine oil. Rotate the pump shaft to distribute oil within the pump body. Insert oil pump drive shaft into block dwith the pointed end facing inward. The pointed end is closest to the pressed-on flange. Place oil pump into position with a new gasket and install attaching screws. Tighten the screws to 15-22 foot pounds of tourque. Clean and install the oil pump inlet tube and screen assembly with a new gasket. Tighten the bolts, then replace the oil pan.
Oil Pan;
Clean of any debris and replace gasket. Fit the oil pan bolts and tighten in two steps. Start from the rear/left hand side and tighten first, then tighten the bolt in the front/right side. Alternate from rear to front, working from back to front and front to back.
Oct 06, 2010 | 1988 Ford Bronco II
Water pump leaks from bottom of housing
You need to replace your water pump assembly. New water pumps are available at your local Honda dealer ( about $135). Get the after market gasket set , it comes with all the gaskets and seals necessary to remove the lower front cover and replace the water pump (K&L makes the kit ($25)). You do have to take off the lower front cover to replace the pump.
Aug 20, 2010 | 1985 Honda GL 1200 Interstate Gold Wing
Need to remove external oil pump on a 95 ford tauras 3.8 v6.what all is involved doing this??
Oil Pump
Removal
  1. If necessary, remove oil bypass filter (oil filter).
  2. Remove oil pump and filter body to engine front cover retaining bolts and remove oil pump and filter body from engine front cover.
  3. Inspect oil pump body seal (6C639), oil pump and filter body and engine front cover for distortion and wear. Replace components as necessary.
Installation
  1. Position oil pump and filter body on engine front cover and install retaining bolts.
  2. Tighten the small engine front cover retaining bolts to 8-11 Nm (71-97 lb-in) . Tighten the large retaining bolts to 23-32 Nm (17-23 lb-in) .
  3. If removed, reinstall oil bypass filter (oil filter).
Dec 04, 2009 | 1995 Ford Taurus
1995 ford f150 fuel pump
will it run off the rear tank?if you have power too the rear pump and the truck runs off it ,its prob a bad pump in the front tank,you need too drop the front tank and replace the pump
Jan 24, 2009 | 2004 Ford F150
Engine codes 1998 ford taurus
This code indicates that the secondary air injection is not working correctly, you need to have the system tested to see if the electric air injection pump works, this pump is very expensive and you don't want to replace it if the issue is somewhere else in the system electronics, a Ford dealer will have the ness test equip to pinpoint the problem.
Jul 10, 2008 | 1998 Ford Taurus
Replacing water pump in front loader whirlpool washer
before changing pump rermove all hoses and ck for coins a quarter can turn on side and block hose also ck down in pump throat 1 screw at front of pump and slide pump back to remove..pump will run $125-$160
Jun 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
125 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
