Question about Canon Video Cameras
No power to take out the tape and the camercorder will not charge
Canon ZR 800 mini DV Camcorder - I was recording this morning and had no problems. The charge on the battery had 1/4 power left. I had 13 minutes left on the tape and went to take the tape out and opened the ''sleeve'' via the specified button and the tape will not pop out. So I shut it and tried again and still the same response and now I notice the the camcorder has NO power. I took out the battery and put it back in with no results. Then I went and tried to charge the camcorder and it will not charge (no red charging light). even took out the battery again and nothing... Is there a way I can at least get the tape without dis-assmebling the camcorder? Is the camcorder just ''dead'' forever at this point? I've only used it a handful of times...
  • 3 more comments
  • sara_schafer Jun 20, 2009
    Canon ZR 800 mini DV Camcorder - I was recording this morning and had no problems. The charge on the battery had 1/4 power left. I had 13 minutes left on the tape and went to take the tape out and opened the ''sleeve'' via the specified button and the tape will not pop out. So I shut it and tried again and still the same response and now I notice the the camcorder has NO power. I took out the battery and put it back in with no results. Then I went and tried to charge the camcorder and it will not charge (no red charging light). even took out the battery again and nothing... Is there a way I can at least get the tape without dis-assembling the camcorder? Is the camcorder just ''dead'' forever at this point? I've only used it a handful of times...
    I have already pushed on the side of the mechanism that says "push" and it won't budge. It has no power which is the strange part. I find it really odd that the camcorder was working with absolutely no issues and just completely died in a matter of seconds. It still won't give any signs of life at all...
    Sorry new to the system! No I don't see a pin hole. To take out the tape it usually comes up and then pops out of the side of the tape carriage (right name?). Right now it is locked down into place and I would think you would need a way to get the Carriage to come up and then pop the tape out of the side. Beyond any help with the tape are there any answers to why it doesn't have any power and won't charge too?
    Do I need to replace the small round battery or the big "pack type battery on the back of the camera if this is the case?
    Thanks, I think this has been the best advice and makes sense. I'll go get the battery and see if it works!
    Top Expert:
  • Canon Master
  • 81,423 Answers
I am 100% sure that your battery has failed, gone open inside, without a battery installed even one low on charge there is no way to disengage the tape from the cassette, a sears of motor driven motions must occur to pull take out from cassette and pop cassette out and back for removal, 100% SURE. U will need to get another battery.
Posted on Jun 20, 2009
  • Marvin
    Marvin Jun 20, 2009
    U will need to replace the large battery, the small battery is keep alive memory for time date and settings
  • 334 Answers
You should be able to manually eject the tape by pushing on the mechanism, I believe it has a spring. Trying hard to remember what the canon looks like. You are able o manually unlock and move the mechanisms
  • seth veloso Jun 20, 2009
    If you are looking directly at the cassete, I believe the mechanisms are on the left, also try plugging it in without the battery in
    hey, you kicked me out without a chance. Oh well, do you see a pin hole where you can insert a paper clip to unlock?
    Sergeant:
  • 296 Answers
Hi
chek this website ndfollow the innstruction its a general solution to ur prob,tht mostly occurs in camcorders,i blliv u will b helpfull
http://www.pechorin.com/m/2003/08/26/SONY_ORIGINAL_PARTS-203491-12.html
regards
My playback video jumps after recording on tape also audio lever rises and fall i does not have this problem when record on the memory card i have a canon Zr camcorder
I have seen this problem many times, the recorder unit needs to be replaced, either something in the tape path has become out of alignment or dirty like a capstan motor or gears or the video head assy is defective. I hope this helps.
Sep 04, 2010 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Feb 23, 2009 | JVC GR-DV800U Camcorder
Canon ZR 600 tape won't load
The capstan motor is broken and needs replacement. You could send it in for repair but it wouldn't be cheap.
Dec 31, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Canon zr200
The heads are dirty, purchase a soft head cleaning tape and run it for 25 secs.
Dec 26, 2008 | Canon ZR-950 Mini DV Camcorder
Wont record anything to MiniDV tape and A/D randomly working
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Regarding can't see picture or time code in playback, it is problem of dirty / clogged video heads. Use good quality video head cleaning cassette to clean heads and hope camera will show playback picture.
Good luck.
Nov 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
Connecting zr85 to vcr to record vhs tape to dv or sd card
I also have a Canon ZR-- left of the lens and the built-in microphones, there is a small panel that opens to reveal several ports. The middle yellow one is the AV In/Out. You can plug in the cable that came with your camera. One end looks like a microphone plug, the other has 3 RCA type plugs- red, white and yellow. These get plugged into your VCR's OUT plugs on the back of the VCR. Place a tape in the camcorder, open the LCD panel and push the REC PAUSE button. On the VCR, press the Play button. When the tape reaches the point you want to begin recording, press the camcorder's Play/Pause button. When you want to stop recording, press the Stop button on the camcorder.
This is also detailed on page 82 of your manual, manuals are available online at Canon.com. Your specific manual is at: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=174&modelid=9739#DownloadDetailAct
Hope this helps.
Nov 20, 2007 | Canon ZR85 Mini DV Digital Camcorder
happened to me too.. only with a sharp vl z3. It happened to me because it was filming while the battery ran out so the film is still in the camera!!! noooo!!! dang it!
Nov 20, 2007 | Video Cameras
Canon ZR100 Mini DV Digital Camcorder Problem
I have a Canon4.gif ZR 10 And it does say remove cassette often and recently it eat the tape and destroyed our recordings.
Does this have something to do was the round small battery1.gif in the front part of the camcorder?
Is this a consumer complaint I feel uncomfortable because we have alot of Cassettes recorded and we are afraid to play them because it might chew them up.
There is a mini cassette player2.gif that can play the cassetes ????
Need Help!!!! What am I going to do ??? PNicioli@sbcglobal.net
Sep 24, 2007 | Canon ZR100 Mini DV Digital Camcorder
Canon GL2 still shot while recording on tape
there no way you can record a still photo while recording at mini dv tape cause the a tape and memory card switch rec mode
Aug 04, 2007 | Canon GL2 Mini DV Digital Camcorder
Video Cameras Logo
70 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
