Question about Epson CX8400 All-In-One InkJet Printer
Changed ink cartridges - error still says I need to change them
I changed my ink cartridges when prompted to (even though the ones I had were new) and it still gives me the exact same error message that I need to change my still brand new, unused yellow, blue and red cartridges. It won't even let me scan even though that has simply nothing to do with what levels my ink cartridges are.
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Call Epson tech support and then Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Posted on Jun 23, 2009
We are trying to replace the black ink cartridge on our brother intellifax 2480C printer but even after loading the new cartridge the printer is indicating that there is no cartridge and the black ink...
Did you have the no cartridge prompt on before you changed the cartridge? If no, then did you remove all packing material. Is this the first time you have changed the cartridge?
Let me know
Jan 09, 2011 | Brother IntelliFax-2480C Fax
Can i print using black ink when im out of color ink it wont let me even though ive changed the settings to print colors as black and white
That's the way Kodak works
It won't allow yu to do anything if any of the lights are flashing or there is a error message
NO RESOLUTION
Get your color ink cartridge replaced by Kodak.
Just say its a new color ink cartridge and printer is saying its empty!!
Hurraay you'll get a free color ink cartridge
Jan 25, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I replaced the black ink and it keeps saying replace ink cartridge. I actually went ahead and changed the color as well even though it did not ask and it keeps saying replace cartridge. HELP! I am a...
Did you replace the ink cartridge with a new one, or did you refill an old one.
Some printers have a memory and can tell which ink cartridge is in them. This prevents them from easily being fooled into printing with refilled cartridges.
Another option is that you changed the ink cartridge without following the specific guidelines for replacement e.g. To replace the ink cartridge, select replace ink cartridge from the main menu, then open the printer panel when the light flashes X number of times.
You might also try unplugging the printer for a couple of minutes the reset it.
Oct 15, 2009 | Office Equipment & Supplies
My printer won't complete the cartridge alignment function. It only prints the first two bars and then stops. When printing the black cartridge looks faded and half printed lines across even though it is a...
My printer does the same thing. I changed the blank ink yesterday (the printer shows the black ink was low) however after trying and trying and not being able to complete the alignment I decided to change the color ink as well.
It worked. Printer works fine now. Sometimes the ink dries up and you have to change it even though you know it should last longer.
Give it a try and let me know.
laura@theprincessandthepup.com
Sep 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Epson PictureMate - can't clean all nozzles & Error P
Many times head cleaning will throw much ink away. 1 time about 10% of ink. After meny times head cleaning, ink will out, and need replacement. May be after head cleaning nozzle is ok, but after replacement, printer do ink charge. It may be distrub the flow of ink at head. Is the cartridge new?. Use CISS for continuity printing.
Jul 26, 2009 | Epson PictureMate C11C623001 Photo Printer
DCP-130C COLOR INKJET
When inserting a new cartridge, you may receive a prompt
"The installed ink cartridge differs from the original ink cartridge for the printer. Your printouts may be different from those printed using original ink cartridges. Do you want to continue using the currently installed ink cartridge?"
If you click Yes, printing will continue. If you select No, you will be prompted to change the cartridge. Manufacturer prompts may vary.
Nov 21, 2008 | Brother MFC 420CN All-In-One InkJet...
New ink cartridge for Kodak Easy Share 5300 will not work
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
I hope this helps
Mar 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My kodak 5300 will not accept the new ink cartridges
Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
Feb 14, 2008 | HP Officejet Pro L7680 All-In-One Printer
Brother MFC 210C All-in-One Ink Cartridges
near empty message is a reminder: plz buy a new cart (but do NOT change until EMPTY). You still can print.
the ink left in an empty cart keeps the system alive when some ink is neede for the automatic cleaning cycle.
If you print until this cart is really empty air will get into the tubes and ph. That leads to faulty printings.
brother had made sure that the amount of printable ink can be consumed. The rest is for service.
Jan 31, 2008 | Brother MFC 210C All-In-One InkJet Printer
Epson CX8400 All-In-One InkJet Printer Logo
190 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
