Question about Hotpoint Washing Machines
Washer keeps filling until it over flows - Hotpoint Washing Machines
  • 6,784 Answers
HI. you will need to replace the water fill level pressure switch. this is located inside the washer near the inlet valve assembly. it has failed.
Posted on Jun 20, 2009
5 Suggested Answers
yalmer
  • 552 Answers
SOURCE: Filling With Water
This is probably a control board failure, which should be replaced by someone familiar with them.
If you are handy, you can do it yourself.
If you need assistance, let me know.
Posted on Mar 04, 2008
barkencoa
  • 3463 Answers
SOURCE: when i start the washer the water just keeps
The prob is caused by the pressure/water level switch not working.
This can be be caused by several different reasons, the main one probably being caused by a blockage in the pressure system, or a faulty pressure switch, and possibly a sticking water in valve.
Check for blockage first, and work back from there if it is not blocked.
Please rate my solution.
Thanks
Posted on Nov 04, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Washer Intuitive Fault code 12 Washer keeps
Hello there:
This code is a indication that your water inlet valve has failed and needs to be replaced when these valves fail they will continue to drain water into the machine even if the unit is unplugged
What you can do is to first unplug the machine and turn off the water to the unit then remove the hoses to the machine then youwill need to remove the back panel of the machine so you can get to the water inlet valve once you get to t the valve remove all of the hoses to it and the wiring and remove the valve then you can open up the valve and inspect it and replace any parts that are worn or rusted like seals or seats or simply replacve the entire valve itself this will cost you about 40 to 60 dollars ok once the valve has been repaired or replaced reinstall the water hoses and turn on then plug in the machine and if you have a cancel feature on it press that than you should be good to go from here run a couple of cycles thru it to ensure it is working properly ok
Hope this is very helpful for you
Best regards Michael
Posted on Dec 01, 2010
TheMobilian
  • 8220 Answers
SOURCE: Roper washer water flow is
Drain hose too low to ground. Must be 30 inches or more above floor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 05, 2011
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
IE code was displayed once. washer will not stop filling or spinning, clock freezes one minute past start up for wash cycle and while washer fills fast and in less than 5 minutes the washer does not stop...
The fault you have is a faulty inlet valve or possibly an electronic controller fault, you need to check with a multi meter if the inlet solenoid is always getting power or if there is constant power, (take care as this is mains power, if in doubt pay a professional to test) if the power stops but the water keeps flowing this is a relatively easy fix with a replacement inlet solenoid, if they fail the water pressure can hold them open and the machine will keep filling.
If there is always power to the solenoid then you have a faulty electronic control board.
May 14, 2017 | LG Washing Machines
I have a kenmore series 80 washering machine. The washer begins the wash cycle mormal. About half-way through the wish cycle the washer begins to fill with water again. It will fill with water until to...
the water level control has gone bad,its located in the top of the washer control panel,four philips head screws gets you in there,make sure you unplug the machine,it has a rubber hose,and four clip on wires,one 1/4 inch screw holds it in place,its job is,it works off of air pressure from the rubber hose that comes from the washer drum,if it don"t read the back pressure from the drum being filled it will over flow.good luck
Nov 19, 2012 | Kenmore 24032\24036 Top Load Washer
Yes it is normal just no hot air
1. When setting the temperature to MAX, blower level to FULL and outside air Vent CLOSED, no hot air comes out after 2-5 minutes?
If YES, when did you last flushed your radiator and is it full?
2. if more than 5 years ago, flush radiator system, instructions are usually in Owners manual. Use a bottle of Radiator cleaner, run egine hot for about 10-15 minutes, carefully open petcock in bottom of radiator to flush out radiator, WARNING, careful as flushed coolant would be boiling hot. As sson petcock is open and water start to flow out, carefully open radiator cap to enhance flushing flow. Use garden hose to fill radiator while flushing until water coming out from petcock is cold and clear.
Once clear, start engine, turn heter full and blower full blast and keep hose in radiator flowing full, leave petcock open until clear water flows out again. Once clear waters comes out, turn off engine,turn off garden hose and let water drain empty radiator. Once it stops flowing out, close petcock snug and put radiator cap on, pull off radiator coolant catch bottle, clean bottle for any debris and dirt. Drain any water, leave bottle empty and put it back onto its place.
3. Fill radiator with 1 gallon (4L) of concentrated coolant, top up radiator until full, fill catch bottle with concentrated coolant, start engine and keep it overflowing until no bubbles comes out and the radiator is fully hot. Once it is flowing good, close and connect everything. Drive with it and keep catch bottle filled as necessarry.
Good luck. Give as vote and good comment if this advise solve youor problem. Thank you.
Jan 05, 2011 | 2000 Chevrolet Suburban
Gcxrpo9odoww GE washer .. On fill up, it over flows onto floor?
Fill switch could be bad, or fill tube could be plugged making water not stop and it keeps filling. The fill tube goes from fill load selector switch to bottom of tub. Remove from top and blow it out. If this doesnt work replace water load size selector switch.
Jan 17, 2010 | GE WBSR3140DW Top Load Washer
When i start the washer the water just keeps filling the washer until it over flows what do you think the problem is
Thanks
Nov 04, 2009 | Washing Machines
My machine is not aggetating it just keeps filling with water
if the water is not over flowing on the floor.make sure your washer is off,then pull the drain hose up to the level of the back control panel you should here water flowing out once this stops.keep the hose up for aminute and restart your waher and it should fill up to the proper level and shut off and start washing
Sep 26, 2009 | Maytag Legacy Series Top Load Washer
Filling With Water
"preesure switch" built into controller, remove 2 screws behind console nad check the clear hose hasnt become diconnected, or perhaps has a crack in it not able to "read" water level
Mar 04, 2008 | Fisher and Paykel GWL11 Top Load Washer
Maytag washer PAV2300 water over flow
from what I am reading on-line, it is the mix valve, aka water valve. Unplug the washer, then see if it still fills. If so, it's most likely stuck open, and needs to be replaced. about $22.00
Feb 21, 2008 | Washing Machines
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Washing Machines Logo
50 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
