Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Singer Futura CE 200 Timing Issue
I have a timing issue with my embroidery machine. When I turn it on, the bar goes back to the start position, but the part where you screw the hoop on does not. Not only that, while it is embroidering the stitching gets off "track" a bit. It is very frustrating. I would love to know how to fix this problem.
SOURCE: Singer Quantum Futura CE-200 Problem
My machine did the same thing. I had several frustrated nights ans then it just started to work. Some suggestions that I had was that there may be dust where the units connect. Not sure what I did, but it worked.
Posted on Jan 02, 2008
SOURCE: Singer futura ce-200 problem, pattern mis-alignment
I have had similar problems in the past.
Do you hear a noise from the embroidery unit when the misalignment occurs ? If so, I suspect that your issue may be that you have some resistance under the hoop. Is there extra material that may be rubbing on the machine or catching somewhere. I have found that if I use some masking tape to keep all of the extra material from hitting any other parts of the machine or dragging under the edge of the hoop this error does not occur. FYI: I also stopped using the "optimize stitch speed" option at the same time. I believe that material dragging was causing the problem, but I still wonder about the stitch speed optimization feature.
Posted on Jul 20, 2008
  • 4 Answers
SOURCE: I recently bought a Singer
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Posted on Jul 31, 2008
dupina
  • 110 Answers
SOURCE: Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
Posted on Nov 17, 2008
dupina
  • 110 Answers
SOURCE: A brand new Singer Quantum
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Posted on Dec 08, 2008
Board
Close your futura file & exit, switch off your futura machine. Disconnect the embroidery unit from the machine,move the hoop carriage a bit to the left then to the right & it should be able to move. Connect back embroidery unit to your futura machine,ensuring the connecting point click properly. Re thread the machine & ensure needle is fully up position. Now you switch on the machine, you will see hoop carriage moving and stop at its zero point. If that is OK and the earlier led blinking gone, you should be able to operate the futura embroidery program again.
Jul 18, 2013 | Singer CE-200 Quantum Futura Computerized...
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
My futura ce 200 quantum embroidery machine is all set up to embroider and the green light is on when I push to start nothing happens. When I push the back stich it goes back to the orginal position and...
Change the fuse in the plug failing that it could be the inline fuse inside the machine normally near where you plug the lead in, if youcan get to that it is a matter of changing it, and the Hoop must be detachedwhen powering on! Otherwise it will not start. Hope this will help you. Good Luck.
Jul 20, 2011 | Singer CE-200 Quantum Futura Computerized...
I need to know how to delete an existing transmission(?) per my singer ce 200
This happens every time I finish a design. First, close thesoftware on your computer. Next, turn off the embroidery machine. Now unplugthe USB cable from the machine and then from the back of your computer. Nowreverse the progress. This will clear the "buffer" between yourcomputer and the machine. It's a bit of a pain to do each time, but it doeswork.
Apr 12, 2011 | Singer CE-200 Quantum Futura Computerized...
Which format should I use for my Singer futura CE-200 when I download embroidery deisgns
The Futura should run any format program but its dedicated program type is XXX so if you have that option I would use that one.
Jan 18, 2011 | Singer CE-200 Quantum Futura Computerized...
Need to retime singer ce-200 sewing machine
What you really need is a sewing machine tech. You are trying to time it the wrong way. The hook tip should be just above the eye of the needle when the needle is in the extreme left hand position
Jan 27, 2009 | Singer CE-200 Quantum Futura Computerized...
I recently bought a Singer Futura CE-200. I was using the embroidery function, but had to stop due to threading problems. When I went back to the computer a few days later my computer was shut down. I...
2. Remove the hoop.
Jul 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Jun 03, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer ce-100 futura
Hi justmewynn, The url I am adding to this post may be of help. It is a pdf file from Singer contain many diagrams of the CE-100. Maybe you cqan page through it and find what your looking for. Hope this helps you. http://www.futura-support.com/files/CE100-Eng_Fre_Spa-77153.pdf
Sep 27, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
143 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
