Question about Kenmore 62802 Electric Dryer
Kenmore dryer will not tumble. dryer gets hot, but drum will not spin.
  • 999 Answers
Can you hear the motor running? It could be a broken belt or something else if the motor is not running. Would need more info to go further.
Eric
Posted on Jun 20, 2009
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: kenmore gas dryer wont heat up
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Aug 11, 2009
heatman101
  • 43501 Answers
SOURCE: TUMBLE DRYER DRUM IS NOT SPINNING JUST GETTING HOT
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 08, 2011
I have Kenmore 80 series dryer. The drum is not tumbling, but the belt is fine. It heats up and the vent still blows. Help!
Does it sound like the motor is starting? If the belt is good, but the drum won't spin, it sounds like the motor is gone or the drum has seized.
Feb 20, 2015 | Kenmore Dryers
Kenmore 80 series dryer does not tumble
check the belt underneath the dryer or if it is gear driv be sure it is free of any debree...
Oct 09, 2012 | Kenmore Dryers
Dryer is heating but drum is not turning. What is the problem?
I would say belt is broken, if you turn the drum by hand and it spins freely then that is the problem, here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
belt diagram:
http://www.applianceaid.com/images/belt-config.JPG
Good Luck Tim
Dec 24, 2010 | Kenmore Dryers
Kenmore HE Dryer not blowing hot air
I have a gas kenmore dryer... the drum runs- it blows air and for just a few minutes warm air but after a few minutes the air is cold. I have cleaned the vent checked it good. I didn't see the fuse on the back I have the bottom latch open and see several wires that can be disconnected; snap together.
Mar 10, 2010 | Kenmore 63942 Dryer
Will not tumble
The most obvious thing to check is the dryer belt. Unplug the dryer, and remove the back panel. Locate the motor and trace the delt from the motor pully to the drum and all the way around, back to the motor. If the belt is on and tight, the issue is probably with the motor.
Regards, W/D
Jul 12, 2009 | Kenmore 64742 Electric Dryer
Does not spin/tumble
sounds like a broken belt.remove two screws at lint filter .pry top up at front and lid should lift and hinge back.should see belt or mark on center of drum.remove two screws holding front panel from inside cabinet.lift the front panel off two clips on front of unit belt probably laying in bottom.change idler pulley too.hope this helps please rate my solution:)
May 31, 2009 | Dryers
IT IS POSSIBLE THAT YOUR DRUM SUPPORT & BEARINGS HAVE GONE, WAS IT SQUEEKING & HAS DRUM DROPPED SLIGHTLY??
IF SO ID SAY THAT IT IS THIS MINE WENT WRONG A FEW MONTHS AGO, SO I TOOK IT TO BITS & IT WAS THE ABOVE PROBLEM, JUST AN IDEA OR YOUR MOTOR HAS PACKED UP, OR YOUR DRUM BELT HAS SNAPPED..
May 22, 2009 | Dryers
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
Very hot at back, making humming noise, but drum isn't spinning.
the drive belt is likely broken
belt replacements for most models are simple and cheap
have no experience of bendix cannot give exact instructions
Nov 02, 2008 | Tricity Bendix TM310W Electric Dryer
Dryer Gets Hot..But doesnt Spin
I don't know what kind of dryer you have, top or front loading, but it top loading it most likely is the belt that goes from the motor & wraps around the drum.
joel
Dec 21, 2007 | Malber TD700 Electric Dryer
Kenmore 62802 Electric Dryer Logo
206 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
