- Turn on your Nintendo DSi and access your system settings by clicking on the wrench icon.
- Scroll over to the third page, and select "Internet."
- Now choose "Connection Settings."
- Click on "None" in "Connection 1."
- Then click "Search for an Access Point"
The system will then display the name of any wireless access point within range.
If The access point has a
gold,
unlocked icon, tap the access point's name, and then "OK." The system will then establish a connection with your router.
gold,
locked icon, the Nintendo DS
i has detected WEP/WPA key security on your router:
- Tap the Access Point name.
- You can either enter your WEP Key, or click "Change Security Settings" to enter a WPA key.
- Tap "OK" again and the system will then establish a connection with your router.
gray,
locked icon, the system has determined your router is set to
WPA security. You need to access the Advanced Setup area of the system to connect with this security method.
- Instead of tapping "None" in "Connection 1", click "Advanced Setup", then click "None" in "Connection 5".
NOTE: All information taken from
http://www.nintendo.com/consumer/systems/dsi/en_na/usb/index.jsp
when i try to conect to the internet only said check the secury setins
i get internet but, when i try to get into my myspace it says to check internet settings
my psp says a connection error has occurred.
a connection to the access point could not be established.
check the security settings for the network and try again.
it always worked and know im mad.dont know what to do.
i for got my pasword
