Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
My red light is flashing in my Kitchenaid side by side refrigerator freezer. The ice was working, but red light flashes and no water comes out. I dumped the ice out, and noticed the bottom of the cube bin has ice in the "mechanisms" that cause the ice to dispense. We do have a filter that registers 0% left in it...but I don't believe that's the problem. What is causing the water to not flow from the dispenser...when the ice maker is still dispensing ice. The unit is 2 years old.
If the filter is clogged (0% left), you may not get the water you are looking for.
Posted on Jun 22, 2009
Ice maker stopped making ice. Red light is flashing. Temperature is below freezing. We've already replaced icemaker and the refrigerator is not even 6 years old.
Ok open your freezer door and observe the flashing red light now push the flapper inwards keeping your finger and hand out of the way of the infa-red sensors you should observe the light it should not flash but glow steady if it does not a fairly simple attempt would be remove the 3 screws on that assembly pulling it away from its location and unplug the harness, now go to the other side and remove those screws and unplug the harness reassemble both sensors and screw back into place push the flapper back in is the red light steady? No then you will need a infa-reds sensor kit I believe they are now well over 100.00. I do hope clearing the pcb on the sensor by unplugging the harness works but if not you now know how to replace the infa-red sensor.........And if the light is working steady and no ice is in the imkr then fill with water and off you go....
May 14, 2011 | KitchenAid Superba Architect KSCS25INSS...
The ice maker has stopped working , a red light is flashing.
according to the led flash cycle, you can figure this out. if you open the freezer door and the light flashes two times, that is normal. if you close the flapper on the left side of the freezer, the light should remain lit, and that means that the optic system is functioning correctly. there is a diagram behind the vent panel on the bottom front of the fridge.
Nov 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stop making ice red light flashing inside freezer water dispenser still works kitchenaid kscs25
the emitter/receiver has gone bad and will need to be changed out. the part number is 4389102 at about 130.00
Feb 28, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker is not making ice, yet the red light that indicates the ice maker is "ON" is flashing..
KitchenAid KSGR25FTSSOO side by side one day just quit making ice. We have blown out the lines and replaced the filter. The red light does blick when we open the door. The water despenser as a flow of water that is real slow. How and what do we do next?
Oct 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker won't make ice
Check temperature of freezer. there is a sensor that will not allow ice to be made if temp exeeds certain level. Near 0 farenheit.
Mar 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
KSRA25IL ice cube tray won't fill
The fill tube is probably frozen. Its in the roof of the freezer. turn off the freezer and heat the roof of the freezer with a hair dryer, being careful not to get it too hot,and it should thaw and work again. If you can put the food elsewhere for a day, just turning it off with the door open should work also.
Nov 11, 2008 | KitchenAid KSRS25IL Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
670 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
