Question about Honda 8 HP Engine
Honda gx160 starts briefly, then dies
My gx160 powers a water pump. Has sat unused for 9 months. Engine starts well on choke but stops after literally a second or two. Refuses to start again within 2 minutes. Will not start without choke. Plug clean and spark good. Have cleaned out carb. Fuel supply to bulb underneath carb is good. Have cleaned the holes in the small brass unit that pushes down into the top of the carb. My suspicion is fuel starvation, but I don't know where else to look for a blockage. Have replaced oil in lower reservoir to max limit. Any ideas would be most welcome. Thanks, Tony
  • 22 Answers
Remove and clean the jet set pilot (black plug on the top of the carbi) replace the o ring if squashed or worn. Clean the small bowl under the fuel stop cock valve, flush the fuel tank, blow the fuel supply line with compressed air and fill up with fresh fuel.
Posted on Oct 10, 2014
    Problem Solver:
  • 15 Answers
Is the air filter dirty? With the bowl as the lowest part of the fuel system, any dirt or water will wind up here. Turn off the fuel valve, or drain the gas tank, then place a rag under the bowl to catch the gas that will run out. Loosen the "nut" that holds the bowl on, and after the gas has stopped draining remove the nut and bowl, but do not let the float swing all the way down! Wipe out the bowl. The "nut" usually contains 1 or 2 very small passages, soak in (or spray with) carb cleaner and use a wire bread-tie or other soft wire to poke out the holes. Blow out with compressed air, if available. Put the bowl back on and try to start it. If it still will not start, it needs a good soaking and a rebuild kit. Take a look at following link to see more solution to different small engine problems. http://solosmallengine.blogspot.com/
Posted on Jun 08, 2012
If inlet valve is breaking always wat is d major problem
Posted on Feb 04, 2011
  • 34 Answers
IF ENGINE IS EQUIPPED WITH NEEDLE
VALVE ON CARB TO REGULATE MIXTURE,
TRY ADJUSTING. PATIENCE, TRIAL AND ERROR WITH VALVE ADJUSTMENT WILL
PROBABLY GET YOU THERE.
Posted on Jun 21, 2009
  • perrycole20 Feb 04, 2011
    if inlet valve is alway broke what can cause it
This is a honda gx160 driving a generator. Engine starts OK but when any load is put onto generator engine splutters then stops. Display says low engine power. Any ideas?
check oil level .low oil causes vacuum in the carb, causing fuel starving .
also check capasator has not blown in generator .
Jan 16, 2014 | 5.5 HP GX160 Engine
Honda gx160
clean the jet and fuel tube located inside the stem at carburetor must unscrew the bowl then the jet fuel tube might also be slightly stuck it should normall fall after jet removal clean all ports re install and walla
Jan 04, 2014 | Garden
Stalls out like out of gas only runs for short time then dies
Clean the air filter out with wd-40, saturate it and just wring it out or use some dish soap and then let it dry out or get as much water out of it as you can. Drain the old gas out and use a little new gas to check the engine while the air filter is off and see if it will start, you may have to cover the intake with a rag to choke it out and suck some gas in there. If it runs re-install the clean air-filter before you operate it for any working.
Sep 25, 2013 | 5.5 HP GX160 Engine
Honda GX160 starts runs dies
How about the carb was it cleaned ???? It's definitely a fuel issue
Dec 16, 2012 | 5.5hp 6:1 Gear Ratio GX160 Engine
Xr100; sat for 4 months and will not start. is choke on in an up or down position it is a honda xr100 2002
If the choke is cable operated then the choke is on when up, pull back the air cleaner rubber from the back of the carb, look inside toward the engine, operate the choke up and down, the choke is on when the flap is closing off the back of the carb, restricting air flow
Aug 27, 2011 | Honda Xr 250 Motorcycles
Yamaha TW 200 starts but won't run.
If the bike has sat for a long period of time without being run - the gas that is sitting in the carb(s) will shellac.. Then the carb(s) would need to be cleaned and "rebuilt"..
Sep 14, 2009 | 2001 Yamaha TW 200
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Can't start the Honda GX160 5.5 HP Electric motor on my Chore Master 2400psi Pressure Washer. Got gas (checked through feed line), new spark plug, switch on, gas, choke ok, throttle a bit funky (about 12...
Is there an oil sensor unit if it is going bad it tells the engine the oil low and engine wont start. I had same problem with my pressure washer, i just unplugged the sensor unit and it started fine ever since
Apr 27, 2009 | Garden
Honda 8 HP Engine Logo
4,805 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
