Question about Elmo Projectors TRV-35H Slide Projector
Elmo TRV-35H "eating" slides
I recently acquired an Elmo TRV35H which is damaging slides when ejecting them. It appears that the slide is being jammed against the bottom of the slide tray slot during the ejection cycle. The same problem occurs with two separate Kodak 80 slide trays.
There is a pivoting plate that appears intended to hold the slide against a fixed plate when a slide is being projected. And this plate is VERY slow to pivot back to push the slide against the fixed plate. I suspect that the slide is being ejected before it is properly positioned by the pivoting plate causing the problem.
I have examined the mechanism for the pivoting plate and notice a white plastic cam that rotates with difficulty. Lubricating the cam wear surfaces with white grease does not seem to have helped. There is a screw in the cam, but it is inaccessible and not clearly an adjustment.
Anyone with experience or suggestions?
    Problem Solver:
  • 12 Answers
CAUTION: Mains voltage connections are exposed once the base of the projector is removed. ONLY attempt repairs if you are confident of your skills!
There are several possible causes for this problem:
1. Kodak produce two different types of carousel magazines - one for glass mounts and one for card mounts. You must not mix glass and slide mounts in the magazine - it causes the focus mechanism to 'hunt' and also causes the slides to jam, as described.
2. These projectors are almost antiques ..... lubricants dry out and the mechanisms slow down and stick! Some 'technicians' apply graphited grease over the top of the dried stuff, hoping it will soak in! Clean as much of the old lubricants off with 'electronic component' solvent on cotton buds particulalrly around all of the cams. Pay particular attention to the slide lifter cam follower - grease here can cause the lifter to only lift, or drop, the slide partially though its full travel. I use 'CopperEase' very, very sparingly on the cams (NOT on the face of the slide lifter cam) and haven't experienced any problems.
You should not adjust the cams on their shaft.
3. The slide pressure plate is acuated through one of the cam followers, opening and closing at the right time. There is a very fine pivot bar at the bottom of the plate. The pivot points can be lubricated with a single small drop of fine industrial sewing machine oil. Avoid 3in1 oil at all cost!
Posted on May 27, 2011
Praxis pump slide handle jammed
1. Get a ruler
2. Push the ruler down the barrel so the end is near the bottom of the disc
3. Jiggle the ruler from left to right
4. Shoot the gun/Press the disc eject switch
Dec 25, 2011 | Nerf Toys
Slides jam in the projector
Chances are if you move your slides into an 80 slide tray your slide jamming will go away. Slides warp and bow due to the affects of humidity on the paper mount and the transparency itself when they are stored. The compartment dimensions in a 140-slide tray do not allow for ANY slide warpage, When the slide warps, it hangs up in the tray (or hits the bottom of the tray ejecting) and the projector will jam. I hope this helps. Good luck !!
Jul 28, 2011 | Kodak Carousel 5600 Slide Projector
I bouht an old Elmo but the lens seems to be missing. How does this projector project anyway What sort of lens system? Thanks to whoever answers
The TRV-35 series are not slide projectors in the normal sense. There isn't a projection lens to enable an image to be projected on a wall or cine screen. The unit is a digital convertor for producing an image via a TV or PC.
Aug 11, 2010 | Elmo Projectors TRV-35H Slide Projector
Need to upgrade video camera in an Elmo TRV-s8
Not sure if that can be done but give Elmo Service a call. www.elmousa.com
Feb 23, 2010 | Elmo Projectors TRV-35H Slide Projector
What size tray doe the Elmo TRV-35H use? What mfg is comparable?
It uses a standard 80 slide Kodak Carousel or comparable tray. Transvue works the best. Sometimes I can coax the Elmo to use a 140 slide tray, but the slides sometimes jam.
Sep 17, 2009 | Elmo Projectors TRV-35H Slide Projector
Forgot how to use it!
Try Elmo's website. Google Elmo TRV-35 H. A PDF of the user manual is available free for download.
Apr 07, 2009 | Elmo Projectors TRV-35H Slide Projector
ELMO document camera only shows documents in black and white, not color. Is there something wrong with the bulb? the camera?
My ELMO unexpectedly stops working during class. The blue power light is still lit but the ELMO is not recognized through my projector.
Any suggestions on what the problem may be?
Mar 25, 2009 | Elmo Projectors EV-200 Slide Projector
Evere 6th or 8th frame james very frustad
I have a slide jaming problem and got this from ELMO support. I have not tried it as yet. I am using 80 slide carousels.
If the unit is jamming like the way you described it may be that the arm needs to be adjusted. If you hold down the SELECT button and turn off the unit while still holding for about 20 seconds at the same time as holding up the arm, you will be able to get to a screw that can adjust the height of the arm.
Dec 20, 2008 | Elmo Projectors TRV-35H Slide Projector
My ELMO video presenter is not working. When I connect it to the video projector via s-video cable, it no longer shows an image, but the projector recognizes there is a signal. It recently fell off of a...
you'll have to check the elmo usa website. you can either send it to elmo themselves, or to one of their authorized service centers (website). if the camera itself is damaged, it's pretty expensive. it may just be the s-video socket.
Dec 11, 2008 | Elmo Projectors HV-8000SX Slide Projector
Elmo Projectors TRV-35H Slide Projector Logo
120 people viewed this question
Top Elmo Projectors Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you an Elmo Projectors Office Equipment and Supply Expert? Answer questions, earn points and help others
