Question about Sanyo DP32746 32 in. LCD Television
Hi guys i have a LG37lc2d tv. The picture is flickering. Need help quickly.
  • 7 more comments
  • ivan_rolle Jun 20, 2009
    This tv has the flickering problem without and cable or video signal. The set has an internal problem. Could be the power supply or one of the inverters.
    I have tried it with a different power out let same results. The tv is coming on but the picture flickers.
    LG37lc2d picture flickering.
    Yes the flickering is coming from the back light.
    The menu is steady.
  • ivan_rolle Jun 23, 2009
    I took the back off and it appears that the whole screen is flickering including the menu.
    The picture is stable not flickering.
    When i took the back off i could the flickering through one of ths backlight inverters. The picture is also not that bright light it needs the contrast to be turned up.
    The solution was very helpful and i would recommend you guys to anyone. Thanks!
  • 10,594 Answers
Please check back light is flickering or its LCD panel.
You can confirm flicker by watching back light at back side of TV, might need to take off back cover and observe back light coming from any tiny hole there.
Does Menu also flicker or its steady?
Let me know to proceed.
Thanks.
Posted on Jun 20, 2009
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Jun 20, 2009
    OK, please check supply voltage to back light are steady?
    Also check control / command signal of back light coming from main board is causing flicker?
    If this command signal that turn On-Off back light is steady then back light board is faulty, replace it.
    Thanks.
    The menu is steady.
    How possible if flicker is coming from back light? every thing should flicker then including menu and picture, any thing on screen would flicker if back light is bad/ flickering.
    Shahid Electronics Jun 23, 2009
    LCD Screen consist of 2 main parts, one is front LCD Screen made of glass and one back light system that provide brightness to view picture in LCD glass sheet.
    You need to identify is it Back Light that is causing flicker (brightness will flicker) or picture itself flicker in LCD sheet and back light is stable.
    Let me know the results to proceed. You are my eyes and ears over internet to solve this TV problem because TV is not in front of me. My response / solution would based on your feedback.
    Thanks.
    OK, so picture on LCD is stable and just back light is flickering.
    It shows problem with back light inverter boards that need to be replaced.
    Master and Slave back light boards are available in Shop Jimmy for $70 each.
    As you can see in TV, board replacement is not so difficult and I hope you can do the job easily.
    Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Usually the first thing you need to check is your HDMI cable and all the connections at the back. Dish network probably has composite video outputs AND RF outputs. You should not have the problem with the CV outputs, but you'll need to have correct cables as specified and have the TV setup look at the video inputs, not the RF.
The only way to troubleshoot this sort of thing without test equipment is swapping out components, doing comparisons between different approaches, reasoning out what is going on.
IF the problem is your RF modulator on the Dish network, which seems unlikely because of the fact that your cable did it too, you could use a distribution amp to boost the signal.
If the problem is a bad RF connection at your TV or via the coax, you MIGHT seen an improvement by boosting the signal. Cost of a distribution amp at the local hardware store is $20. Some older TVs have 75 and 300 Ohm inputs. Are you using the right one? This matter because there are other internal components that might be involved, misfired, broken, missing.
To me, it sounds like the TV is insensitive to RF. The old cable box isn't. It either demodulates the signal and it comes out stronger, or it has an internal distribution amp that does the boosting directly.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jun 20, 2009
    Hi
    I believe its the power supply thats gone bad. Try to use it with different power outlets. Please check this service manual for more information.
    Thanks
    Rylee
  • Rylee Smith
    Hi
    Have you tried a different HDMI cable/port? If you have then how old is the lamp, it could be the lamp has gone bad, It does sound like an HDMI incompatibility issue.
    Thanks
    Rylee
  • Rylee Smith
    Hi
    Check for a failing solder joint in the power supply; these tend to be intermittent and random. Most semiconductors just flat die under the right conditions but it is possible for a power semi to fail internally exhibiting just the same behavior. Since both audio & video are down together, I would check the main power supply first.
    You won't hurt anything if you pull the AC plug overnight, remove the back panel and look inside to see if you have a separate board with larger components on it; cylindrical ones (capacitors) and largish blocks (transformers & chokes). If you find this, check for a part number or have the set's model number handy and call the mfr.s service to ask about repair or replacement costs. You can ask them too, if my diagnosis sounds
    It would seem that the video processing section is sensitive to heat. You do not indicate how old the set is, so if under a year, it should still be under warranty and you should request warranty service. Provide as many details about when the problem occurs so that it can be reproduced.
    If the unit is out of warranty, check to be sure that any fans on the top or bottom are free from dust and are turning. Also, you can open up the back and carefully reseat all of the cables and connectors. A bad connection at one of those could show up like this too. If all of that fails to resolve the problem, then the unit will need to be seen by a servicer. There are no user serviceable parts inside other than the actual boards and those are not cheap. It is possible that a servicer may spot something that we can not see, being remote and all.
    Please do accept the solution and revert for further assistance.
    Thanks
    Rylee
Rca 42in full hd lcd picture flickers
If the picture on your TV flickers, there may be a simple fix. Here are some possible answers and suggested solutions:
1. Your set-top box may need a simple reboot. Unplug the power connection to the set-top box for about 30 seconds. Reconnect the power and turn the set-top box back on.
2. Check all of your cables for a loose connection by tightening each one with your fingers.Flickers can sometimes be caused by bends in rigid cables, too.
3. If your picture flickers to a black or blue screen, you could have a bad set-top box. Contact your cable or satellite service provider about installing a new one.
4. If you still have audio, the flickering could also mean that you have a failing backlight.
For additional troubleshooting information, check out the chart at TV flickering for more solutions. I hope this helps!
Sep 14, 2012 | RCA Televison & Video
Sound but no picture
hi there.presumably you get a quick flicker of picture when first switched on?.If so, you will need to replace the inverter board,readily available on ebay.
another problem these sets can have is no picture in the middle,just at the sides, and gets progressively worse over time,until there is no picture.this problem is caused by two 680uf,35v capacitors on the power supply,which burst as they are under-rated budget parts,all too common these days!
hope this helps somewhat!regards,
steve
Jul 31, 2011 | Goodmans GTVL32W27HDF 32 in. LCD TV
TV LG37LC2D... When powering the tv ON, the green power light blinks rapidly but no picture and no sound. What can be the problem?
Failed power supply due to shorted circuits in the power supply or in the backlight inverter board, bad DC filter caps.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 06, 2010 | LG 37LC2D Television
Picture is flickering then going off
tae your tv to a w/shop tech
your tv has a dry joint or one of the active components is heating up
or a supply is varing
Mar 06, 2009 | Bush 2871NTX 28" TV
Screen/Picture Flickering
alo all..
i got problem wif my TV... sony wega trinitron 29inch..
- last 2 night... the TV @ screen slowly lost color for 2-4second... and after that it suddenly turn off for 5-10second and turn back on itself. the led blink 3-5times....
what the problem to my TV?
Jan 09, 2008 | Sony KP-46S25 TV
Picture flicker
You can get info at ctechnicians.com
Dec 22, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Snapping noise and flickering pic when set is first turned on
The hi voltage cable a red wire with gray cup that its attached to the picture tube needs to be sealed , that can solve the problem. 40.00 dls depending on the tech . dangerous to do without the knowledge ,picture tube need to be discharge before, try to seal to avoid accidental hi voltage discharge . if you need more help let me know
Jun 14, 2007 | RCA F27669 TV
Sanyo DP32746 32 in. LCD Television Logo
143 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
