Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Blinking Clean light in Whirpool dishwasher
Hi. All was well with my whirlpool mod. du1101xtpb7 dishwasher when in seemed to get locked in the clean stage. the clean light now blinks 7 times and them stops, blinks 7 more times than stops again. when i hit the cancel/drain button the pump comes on but there is no water to clear out.
I can not get the the cycle to clear to wash my dishes. the unit is only 2 years old.
Any Ideas. Whirlpool said something about the heating circut (something like that) being bad.
  • Anonymous Mar 17, 2014
    7 blinks no water
  • 111 Answers
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Posted on Jun 20, 2009
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirpool D/W Mod. GU2275XTVYO. The clean light flashes 7 timed, pauses and flashes 7 times again... Is that in the board? It will cancel and drain but won't do anything after that. Please...
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Jan 25, 2011 | Whirlpool Gold GU2275XTV Builtin...
WHIRPOOL DISHWASHER CLEAN LIGHT SATYS BLINKING AND IT WON`T START WASH CYCLE
you have either a bad heater and or your water temp is too cold
toggle heated dry and high temp wash withing 8 seconds until all the lights light up
then hit cancel you should be able to use it now
Aug 24, 2010 | Whirlpool Dishwashers
Blinking Green Light
This indicates that the water did not heat properly. Follow the link below for instructions on what causes this and how to reset the control so you can use the dishwasher.
Blinking Clean Light
May 31, 2010 | Whirlpool 24 in. Built-In Dishwasher w/...
Blinking clean light
This blinking indicates a failure to properly heat the water, the link below will have instructions on how to reset the control so you can use the dishwasher and it will provide areas to look as to why it failed. Let me know if it was helpful.
May 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
MY whirlpool dish washer is stuck on "clean" status and light is juts blibking on and off
See this thread:
http://www.fixya.com/support/t157405-clean_light_dishwasher_stop_flashing
Sep 06, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Model # DU1055XTPQ3 WHIRPOOL DISHWASHER RESET CODE
chris72 had the solution to my Whirlpool DU1055XTPQ3 not turning on. Per Chris's suggestion, I pressed back and forth between sani rinse and heated dry. All the lights came on as it reset and it was good to go. The dishwasher started up immediately. Saved me a service call, THANK YOU Chris!!
Aug 07, 2008 | Whirlpool 24 in. DU920PW Built-In...
Clean light flashing
Here is the solution to your problem. Push in this order, High temp, heat dry, high temp, heat dry, all the lights will begin to blink. After they stop, the dishwasher will start. Press cancel twice.
May 06, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
748 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
