Whirlpool top loading washing machine water comes out of the bottom
Whirlpool top load washer leaking water into tub with unit in off position
Posted on Jan 12, 2010
    President:
  • 3,113 Answers
Water pump will leak in the front area. See you tube for a video on this.
Posted on Jun 20, 2009
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
After using my Whirlpool Cabio Top Load Washing Machine to do a load of laundry, I can still hear water sitting inside.....What can I do?
There water in the balance ring at top of basket/that has to be in it...Can you see water at bottom of basket?
Feb 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washing is outside in a shed and water supply has been frozen, I have now got water supply sorted but machine is leaking water at the bottom back corner even though its not even on. Any ideas?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following Whirlpool Service manuals for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It sounds as if the discharge tube from the pump to the back of the washer has split or come loose probably from freezing and thawing.
See the following for how to remove the cabinet to check the tube and pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5cac791c099cfeceeefa8f469d527d82
Dec 04, 2010 | Kenmore 24032\24036 Top Load Washer
Water leaking out of bottom - whirlpool top load
tip it to the back look at the pump for signs of water stains or water drops if so replace just 2 clips to remove
Aug 21, 2009 | Washing Machines
There is water draining from underneath the machine?
I have the same unit, I had to replace my drain pump and clean the entire machine out. THis unit has many design flaws however once they are corrected with new parts it is a good machine.
Mar 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Leaking
Sheets Or Comforters? This Normally Occurs With An Overload Such As Pillows And Comforters Due To The Large Circumference. Which Simply Means That Anything That Has A Large Area Will Make The Water Come Over The Top Because When The Machine Is Running The Spin Cycle The Large Area Of Fabric Covers The Side Of The Machine. Actually Causing Water To Spin Off The Top Of The Fabric And Over The Sides Of The Washing Machine Bucket Thus Ending Up On The Floor Below.
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Water Leak
is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
Oct 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
