Question about Whirlpool Washing Machines
Whirlpool washing machine makes grinding noise
Top Loading
Model: LXR9445JQ1
purchased 1/5/2002 for $400
The washing machine has worked very well until last weekend. I put in the water/soap as usual and let it agitate for a short time, then put in the clothes (as I normally do), roughly 10-15 minutes later a very loud grinding noise started coming from the washer. It had also stopped agitating and was full of water (however I did not pay that close attention to the dial to know where in the cycle it was - disbelief got in the way).
The grinding noise stopped when the washer knob was pushed in to stop the cycle. And, when manually placed on spin the water did drain out.
Is this problem known?
Is it fixable for a reasonable price? ($100 or less - if it's more than that I would get a new one that uses less water.)
Or should I send this washer to the salvage yard?
  • mcadwell Jul 26, 2009
    MrQuickFixit is brilliant! That is exactly what was wrong. And, following the directions you gave me, it was quite easy to fix. Thankyou thankyou thankyou!!!
  • 97 Answers
Hello Friend, Your solution is a real quick fix. The problem you are having is very common, your motor coupling has broken and that is what's making the grinding sound, also in this condition it will always pump out the water. Go to your local appliance parts store and purchase a new motor coupler, your cost should be under $25. It's very simple to remove old and install new coupler. First remove two screws from control panel and tilt control panel backwords exposing area under panel. You will see a metal clip on each side of cabinet under panel. Remove these clips, and unplug wires from plug in on cabinet. Remove cabinet by lifting up in back and tilting forward. Once removed you will see the innerworkings of your washer. Lay washer on it's back and remove the two spring clips that hold water pump in place and remove water pump. Leave water pump hooked up just move to side out of your way. Then you will remove the two screws that hold the motor clips in place and just snap the motor clips off. Be sure to unplug the wire harness plug from the motor. Just simply lift the motor straight up and off of the transmission. There you will see the motor coupler broken and to replace, just pry old one off transmission and motor with large flat head screwdriver. You will notice that one half of coupler is attached to the motor and the other to transmission. In the coupler kit you will receive both pieces and the rubber center connector. Just replace all the old with all the new and your problem will be solved. Happy to help, Tim.
Posted on Jun 24, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have an LG top loading washer, model WT4870CW. During the wash cycle the machine makes a grinding noise. The noise does not occur during draining and spin cycles. Any idea what could be the issue?
Is your agitator moving back and fourth, when on wash cycle
Could be your plastic agitator spline is stripped,
Take it out and check the plastic teeth is not worn inside.
Dec 25, 2014 | LG Washing Machines
Kenmore (Whirlpool) top loading 110.24642300 washer will fill but will not drain or spin. The machine makes a grinding noise when it tries to spin.
This is usually caused by the motor coupler. This is very inexpensive and easy to replace. Here is a video this will walk you thru this disassembling and replacing a motor coupler in a direct drive machine. It may be a different model but the troubleshooting and replacement will be the same. You can also enter your model # for your specific model to get diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Dec 01, 2010 | Whirlpool Washing Machines
I have a maytag mav6300awq top loading washing machine. In the spin cycle their is a loud noise it sounds like a grinding noise. Then I smelt something burning. I took off the the top of the machine and...
Sounds like the transmission has gone to junk. The best way to fix it is with another one. To do the repairs it needs will cost more than a new one.
Jul 07, 2017 | Washing Machines
Will not spin and making grinding noise
a grinding noise sound i think it come from ballbearing you can chang by qualified person
Apr 17, 2009 | Whirlpool LSN1000LW Top Load Washer
Whirlpool LXR94 leaks in front left
Taking the back off any washer rarely helps. Most are accessable from the bottom (you have to flip the machine on its back PLEASE BE CAREFUL, check the pump hoses (normally attached by clips to the motor assembly). As far as calling the dealer, you have to decide if its worth your time and effort.
Jul 08, 2007 | Whirlpool LXR9445JT Top Load Washer
Washing Machines Logo
1,591 people viewed this question
Dan Webster
Dan Webster
Sal De
