Same problem but with a joys mt871
Hi i have the same problem brought a joys plotter mt871 does not contain a disc to install these are mass produced in china it came with a usb lead will not pick up the driver so have all the right settings in (com 3) as instructed on the joys help line (national rate number) at 60p per min so spent £26.00 trying to sort still no joy now tried 9 pin comm lead sends info from computer to plotter but will not fire up running this with artcut 2005 that came with plotter is there any way of getting the driver to install without the instalation disc make is kering630 ???
leart my lesson dont' purchase anything from joy,s
  • 390 Answers
SOURCE: Installation of a downloaded driver for Lexmark X1290 All-In_One
For those of you who have downloaded the appropriate vista driver for your printer. Go to device manager on pc (control panel, hardware and devices etc) Select uninstall printer driver, as you want any old references to xp one deleted. Now, place new disc or dicc with new driver files in and your install new hardware program shopuld self start. IF not you can manually do it by going to add new hardware wizard, and select own information to suit yopur needs. But win vista should automatically find the new drivers.
Posted on Feb 14, 2008
otacon
  • 1944 Answers
You need to download the Vista compatible setup here from Lexmark,
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:567:0:0&searchLang=en&os_group=Windows%20Vista&target=
Run the setup after it finishes downloading but ONLY connect the printer to the computer when the setup instructs you to do so.
Posted on Apr 18, 2008
I bought a Lexmark X1290 printer and installed a wrong driver (for WinXP) from the enclosed CD. Then I could not run the All in One program. After many reinstallation attemps, I finally found a solution (which is unfortunately quite hidden at the Lexmark website):
1) Unplug the printer's USB cable from the computer.
2) Download the cleaning utility from ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/.
3) Double-click on the cleanup utility and follow the on-screen instructions to run it.
4) Restart the computer.
5) Download all files from ftp://ftp.lexmark.com/driver/inkjet_drivers/Cleanup/reg/
6) Follow the instructions in the "Vista BackDoor Instructions.txt" and delete all remaining Lexmark
keys in the registry.
7) Restart the computer
8) Download a proper driver for Windows Vista from the Lexmark website.
9) Install the driver accordingly to the instructions (it's important to plug the printer's USB cable when you are ask to, not before)
The problem with Lexmark Unistall and CleanUp Utility is that you cannot delete all Lexmark registry keys while you arelogged in the system. This is anellegant way how to circumvent the problem.
Posted on Sep 14, 2008
SOURCE: installing new wireless printer hp office jet 6410 from my mac
install driver without hooking up printer with usb. choose hp... (bonjour) then when it tells you to turn on printer and connect with usb don't! again it will come up bonjour. pick that device and voila! after 10+ times of installing and uninstalling i finally got it to print wirelessly!
Posted on Mar 19, 2009
SOURCE: plotter mt871 will not communicate from computer to plotter
Reset the plotter and enter the setup menu. Calibrate your baud rate which should normally be 4800.
Posted on Aug 24, 2009
HP 1055cm+ Plotter: System Error 060308 00000008. How do you access the printheads when the plotter has this error? None of the console buttons respond.
This is an APA regulation failure. Not a good error. First you need to remove all the printheads and clean the contacts on the printheads and the contacts on the flex connector inside the carriage assembly that mate with the contacts on printheads. If no joy you need to perform the electronics test contained in the service manual link below. If still no joy then you need to replace all the printheads.
Aug 22, 2017 | HP Office Equipment & Supplies
Plotter hp 4000 message maintenance #2 required
Maintenance kit 2 includes the following
This Preventive Maintenance Kit contains the following components:
?? Complete Carriage Assembly (? Page 8-53).
?? Ink Supply Tubes and Trailing Cable (? Page 8-33).
?? Scan-Axis Motor (? Page 8-59).
?? Belt Assembly (? Page 8-58).
?? Most Left Spittoons (? Page 8-43).
?? Middle Left Spittoons (? Page 8-44).
?? Scraper (located on the Service Station).
Once installed, you reset the counters, link for manual:
http://www.partsnow.com/docs/service-manuals/hp-designjet-4000-service-manual.pdf
Feb 11, 2015 | HP Office Equipment & Supplies
Hi there. Does anyone have a mannual how to use the control panel on the bottom right hand side of the screen? I've just brought this one today and the User disk that came with has nothing on it! many...
You dont need the driver disc, windows will install any driver that is needed, the disc usually contains colour temperature profiles if needed for certain graphical programs.
usually you just press the menu button and go thru the options, modern pc's and monitors dont need much, if any adjustment, but if you do want a little play around with the controls, look here. http://www.retrevo.com/support/AOC-19LVWK-Monitors-manual/id/575bh239/t/2/
Aug 20, 2010 | AOC 19LVWK LCD Monitor
Mt871 driver
Hi, you can find and download driver from this link;
http://driversdownloaddriver.com/tag/index_397.html
Good Luck
Dec 10, 2009 | Computers & Internet
1. PEN NOT LIFTING. HOW DO I ADJUST PEN LIFT 2.PAPER SKEWS TO LEFT 3. NEED SERVICE MANUAL ON SUMMAGRAPHICS PLOTTER HI7200
Installing Pens
Most types of disposable pens must be activated before using the for the first time. If you are installing a new disposable pen:
  1. Press down on the pen cap to break the internal link seal.
  2. Holding the pen with its tip pointing down, shake the pen to start the ink flow.
  3. Remove the cap and test the pen for ink flow on a scrap of paper or media before installing it in the plotter.
    Some types of pens require adaptor sleeves to fit the pen holders in the pen changer and pen carriage. Insert each pen into its adaptor sleeve, if required, before installing it.
Using the Pen Changer
You may find it easier to temporarily raise the pen changer arm to install pens. Press the widest part of each pen into the jaws of each stall in the pen changer. After installing all the pens that you plan to use, lower the pen changer arm until it latches into place.
Notice that the pen changer stalls are numbered 1 through 8 from right to left (viewed from the front of the plotter).
Note: Make sure that the pen changer arm is in its lowered position and latched into place each time you power on or reset the plotter so that the plotter will correctly change pens.
Operating Without the Pen Changer
For operation without the pen changer, position the pen changer arm in the raised position and install a pen directly into the pen carriage by pressing the widest part of the pen body into the jaws of the pen holder on the pen carriage. You can still produce multi-pen plots, if desired, by enabling the PEN PAUSE parameter--------------Online KeyThe Online key toggles the plotter between on-line and off-line operation. The mode is displayed with each key press.
The plotter is initally in the on-line mode at power-on. In the on-line mode, plotting operations are enabled. When media is loaded in the plotter and the plotter has been selected (see below), an on-line plotter begins executing plotting commands from the input buffer as soon as they are received from the host computer.
In the off-line mode, the plotter can still receive data into its input buffer if it has been selected, but plotting operations do not begin until the plotter is switched on-line. The plotter can be operated manually in the off-line mode using the following control panel keys:
  • Pressing the left or right arrow key moves the pen left or right.
  • Pressing the up or down arrow key moves the media in or out of the plotter.
  • Pressing the PEN SELECT key accesses a menu to select a given pen from the pen changer.
  • Pressing the PEN UP/DN key raises or lowers the pen.
Pressing the Online key during plotting switches the plotter off-line and suspends plotting.
Pressing the Online key again will cause plotting to resume at the point of suspension. ------------------Pen Up/Dn Key
The Pen Up/Dn key raises and lowers the pen when the plotter is off-line. If there is no pen in the carriage, pressing the Pen Up/Dn key causes the plotter to retreive the currently selected pen from the pen changer (if the pen changer is installed and is in the lowered position).
Note: After approximately two seconds of no pen movement, the plotter will automatically raise a lowered pen to prevent ink from bleeding on the media, until the pen is moved again. If the pen is not moved for the period set for the AUTO-CAPPING parameter , the plotter will return the pen to its pen changer stall. To restore the currently selected pen to its previous position on the media, press the Pen Up/Dn key or an arrow key. Pen Select Key
When the plotter is off-line, pressing the Pen Select key allows you to select a pen from the pen changer. After pressingPen Select, press the <-- --> keys until the desired pen number is displayed on the lower line of the LCD, then press the Enter key. The plotter will retreive the selected pen from the pen changer.
The Pen Select key is also used in the Configuration Menu,
Oct 16, 2009 | Computers & Internet
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
Plotter mt871 will not communicate from computer to plotter
Try getting some generic drivers for plotters and see if they do anything... I would also suggest that you get a JetDirect card or something to interface the Plotter with your network, this should take any misscommunication away.
Jun 20, 2009 | Computers & Internet
Unable to find Mass Storage Controller Driver
The mass storage controller is generally for usb devices that you've plugged in. USB keys, memory cards etc.
This kinda falls under the realm of the USB drivers for your mainboard... which if they're working, you don't need to do anything. XP service pack 2 supports USB2 just fine, but service pack 1 will require you to get your manufacturers drivers to get USB2 working at full-speed.
Why do you want to change the default driver anyway??
Aug 20, 2008 | Computers & Internet
133 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
