Question about Car Audio & Video
Immobiliser fault i have 1.6e rt megan on a 97 plate i can not unlock the car with the plip i can with the key but i can not start the car due to the immobilser still being active help please>>
  • ade_ingram Jun 20, 2009
    thnk you for your reply, this a factory fit immobilser, ihave tried a few tricks i:e remove the fuse and tryed reseting ecu, all failed to disingauge the immobilser.does any 1 know where the immobilser box is located on the 97 megan
    unbelievable, worked a treat, took a litle while to input the right code from keyfob as the number in my fob had 10 digits and i only need 5 of them but so worth the effort. THANK YOU THANK YOU THANK YOU,
    Scholar:
  • 63 Answers
You sound like you are familiar with your hardware. Did you install this system yourself? If so you should know how to re-route back to pre install on the circuit that has been rendered unusable. If not you need someone familiar with that system or an installer with the schematics of it or a new controller, whichever iis available. good luck!
Posted on Jun 20, 2009
How can i disconnect the immobiliser on my rover 45
has your car got the round plip ? if so and you have checked the batteries and it locks and unlocks the car but does not disarm the security system the problem could be the scu which is located on the lh bulkhead/ footwell area inside the car and is prone to water damage, it is not easy to disconnect the imobilizer because it works in conjuction with the engine control module which needs a ok to start signal from the scu before you can start. if its the older type plip, you can disable the immobilizer by using the key access code which you should have in your handbook/info pack. this involves turning the drivers door lock in both directions a number of times to match the code, if this info does not help you need to find somone with rover testbook or t4 diagnostic equipment, hope this helps.
Feb 08, 2015 | Rover Cars & Trucks
How to re-programme new car batteries in car key ?
1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds.
2. Then turn ignition switch to OFF position. Leave key in ignition switch.
3. After 2 seconds, the system will enter programming mode and will flash the warning lights twice.
4. Press and HOLD the unlock button on the Plip.
5. While pressing the unlock button, press the lock button 3 times.
6. Release the unlock button.
7. The warning lights will flash once to indicate successful programming.
8. Repeat procedure 4 to 7 for up to 4 plip key's.
9. When completed turn ignition ON, and the warning lights will flash 2 times.
10. Remove key, and check all plip key's for operation.
NOTE : The programming mode will stop when either the ignition is switch ON, 4 plip keys have been programmed or no input signal either from the switch or plip keys has been received for 120 seconds.
Nov 08, 2014 | Cars & Trucks
How to code new batteries in car key
Nov 08, 2014 | 1999 Nissan Primera
I have recently had to have a new keycard done for my 55 plate Renault Megane as the central locking on my keycard stopped working and I couldn't access the vehicle, now I have two keycards that both
change batteries if this is not the fault. twist key slightly while trying to lock/unlock if key works transponder terminals have broken off the board
Oct 06, 2014 | 2005 Renault Megane 1.4
Will I be able to start and use my car if the key fob/plip isnt working?
everything should be ok as long as u got the key to start the car
Jul 07, 2014 | 1999 Renault Megane
How do i reset central locking on a micra 04 reg
Try the following:
"KEY FOB PROGRAMMING
NISSAN
SYSTEM DESCRIPTION
The Central Door locking is controlled by the Multi-Remote Control system which controls
the door locking, door super locking and hazard reminder. When the doors are locked and
unlocked the unit flashes the hazard lights once for lock and twice for unlock.
A maximum of four remote controls are allowed to be programmed.
ALMERA
ALMERA TINO
PRIMERA
MAXIMA
MICRA
SERENA
VANETTE CARGO
TERANO II
Ensure all the doors have been unlocked, either by using a good transponder key or remote
control plip key.
Procedure
lights twice.
8. Repeat procedure 4 to 7 for up to 4 plip key?s.
10. Remove key, and check all plip key?s for operation.
for 120 seconds."
Mar 12, 2012 | Nissan Cars & Trucks
My es300 is not starting - it appears to be immobiliser problem - i have tried both the keys - it has a 1 month old battery and all inside electricals are working ok
your key transponder may be faulty, you would need to take the keys to a dealer and see if they can read the codes from them, if not, the car wont see them either.
If a yellow key symbol is flashing on your dash then this is another indicator of the key failing. If the plip cannot unlock the car either and only the key blade will do it, then the immobiliser may need re-coded to your keys after the battery replacement, or if it has worked since then, and the stopped recently, I would suspect the transponder chip in the key.
Oct 24, 2009 | 1996 Lexus ES 300
Renault megane key fob wont work
I had the same problem with mine
your key fob is now out of sync with the ECU to sync them just follow this link (renault will charge up to £180 for new key and to sync it)
http://renaulthelp.110mb.com/ImmBypass.html
Jan 03, 2009 | Renault Megane Cars & Trucks
Renault megane dynaique 2003 cutting out and wont start
the carb needs cleaning, thats what it was on mine, i thought it was spark plugs but took it back to main dealer and they fixed it but cost £££
Oct 03, 2008 | 2003 Renault 181
Key fob not working
hello mate.. if it has stopped working you might want to check the battery first.. if you are sure that the battery is fine then consider reprogramming the fob to your car.. here are the steps to follow.. NISSAN
Remote Control Fob Procedures:
the door locking, door super locking and emergency hazard reminders.
When the doors are locked and unlocked the unit flashes the hazard lights once for lock and twice for unlock.
A maximum of four remote controls are allowed to be programmed:
ALMERA
ALMERA TINO
PRIMERA
MAXIMA
MICRA
SERENA
VANETTE CARGO
TERANO II
control plip key.
Procedure:
2. Next, turn ignition switch to OFF position. Leave key in ignition switch.
3. Wait 2 seconds then the system will enter programming mode and will flash the warning
lights twice.
for 120 seconds.
http://www.autokeysquad.com/nissan-fob-programming
i hope this can help you.. :)
Jul 28, 2008 | 2005 Nissan Sentra
Car Audio & Video Logo
113 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
