Question about Sharp Microwave Ovens
Sharp carousel microwave model r-7240
How do you set the clock to the correct time
i have looked for a manual for this but no joy
cheers
MicrowaveSvc
  • 9098 Answers
SOURCE: manual for sharp carousel R-230 AV
Models R420D and R520D also have this common feature found on Sharp microwaves. You can download that manual free at the link below (not my link) and the section on Compu Defrost should help you just fine. http://www.htsarebates.com/files/mic_man_420,520D.pdf#search=%22sharp%20compu%20defrost%20filetype%3Apdf%22 Or you can just do the Google search below and you'll end up with a list of several manuals you can try: "sharp compu defrost filetype:pdf" (without the quotes)
Posted on Sep 21, 2006
  • 110 Answers
SOURCE: i have a sharp carousel
The easiest way I can remember is to turn off the power, then back on... this will make the display flash, then press stop/clear.
Then press clock, enter the time eg: for 9 am or pm enter 9.00 and press clock again.
Hope this helps.
Posted on Apr 25, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
fieldy14
  • 456 Answers
SOURCE: Looking for instruction manual Sharp \carousel
if you google the model number and the brand you should be listed with a series of sites that supply manuals, service manuals, etc.
Posted on Aug 16, 2009
SOURCE: how to set the clock on my sharp carousel
Touch STOP/CLEAR pad.
Touch TIMER/CLOCK pad.
Enter the correct time of day by touching the numbers above in sequence.
(for example: for 12:30, touch 1 2 3 0)
Touch TIMER/CLOCK pad again.
Posted on Mar 11, 2010
I cannot reset clock
Touch Timer/Clock pad and number 2 pad.
Enter the correct time of day by touching the numbers in sequence.
Touch Timer/Clock pad again.
Aug 15, 2015 | Sharp Carousel R530EST Microwave Oven
I can't set the clock. It's a Sharp Carousel II w/ ESP - R-4K82C
Press the clear button twice and then the clock button. You can now enter the time. Press the clock button when set.
Jan 03, 2011 | Sharp Microwave Ovens
Unable to set microwave clock
sometimes the clock resets after unpluging for a short period. when you restart / power up note the time it starts at generally 12:00 miday good luck gbw
Feb 07, 2010 | Sharp Microwave Ovens
I have a Sharp Corousel Microwave R230KW.
On most Sharps, the sequence is:
Clock > 2 > 3 > 5 > Clock (for 2:35)
or
Clock > 2 > 3 > 5 > Start (for 2:35)
You can order many Sharp manuals free here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 26, 2009 | Sharp Microwave Ovens
How to set the clock on my sharp carousel microwave
Sep 25, 2009 | Sharp Microwave Ovens
How to set clock on sharp microwave
normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
Sep 21, 2009 | Sharp R-1480 Microwave Oven
Cant set the clock
hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
May 10, 2009 | Microwave Ovens
How to set the time, and can i download a usermanual anywhere? Thanks
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again...should set.
I have not seen a manual on-line for your model...ut htere are many others...perhaps browsing thru a few might help you. If not...try going into a store and looking for that model...the management might copy if for you...I would. :-)
Apr 24, 2009 | Microwave Ovens
I am looking for a manual for a microwave it is a sharp carousel model R-380C.
go to the sharp site and look up your model #. they should have it for you there or be able to get one close to what you have.
Apr 09, 2009 | Sharp Microwave Ovens
The door on my Sharp Carousel II Microwave Oven will not open. The display says LOCK. Looking at my booklet revealed that there is a safety lock feature. I tried to cancel by touching Autostart/clock,...
Sounds like a drawer type microwave or a combo oven and microwave?
If your manual's instructions didn't fix it, you can try a hard reset.
Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If you still need help, please reply back with your model number so we can help you.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
Jul 15, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
104 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
