Question about Garden
NEED TO KNOW HOW TO ADJUST CARB ON A BOLEN'S BL150 17' CUT 31 CC WEEDEATER
4 Suggested Answers
SOURCE: Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
Posted on May 18, 2009
SOURCE: manual for craftsman weedeater
Try:
http://www.managemyhome.com/mmh/owner_manuals
Posted on May 19, 2009
canbruce75
  • 1776 Answers
SOURCE: Gas/oil mixture for my Homelite Trimlite weedeater 25 cc
50:1
Posted on Jul 12, 2009
I have a 31 cc Ryobi weedeater. When I put it on full choke it starts. Then when I put it on half choke, It starts, revs good for a few seconds then dies. What do I need to do?
This is fuel starvation, check/replace the fuel filter in the tank, no better then you need to make an adjustment to the carb, unfortunately you may need a special tool as many carbs today have anti tamper adjustment screws ( they have no screw driver slot in the head ) check the head of the screw and order the relevant tool off e bay, once you have the tool make small adjustments at a time, they are fuel screws not air screws so unwinding them will richen the mixture, make the adjustment to the L screw. this will be the screw nearest to the cylinder and will help with acceleration, the H screw will control the maximum rpm.
Apr 17, 2018 | Ryobi Garden
Bolen 160 adjustments weedeater
Remove the carb and disassemble, clean the jets with compressed air or a thin peace of wire.
Aug 20, 2017 | Cars & Trucks
I purchased the weedeater last year and it ran fine. This year I can only set the choke setting on #2. If I place the setting on #3 the motor will cut off. Please help. Thank you.
Its very important to drain fuel at end of season and use stabilizer but now the car will need to be cleaned you can do it yourself with carb cleaner that carb off and remove both covers spray real good hope it works if not new carb needed
May 03, 2015 | Garden
How to adjust carb on F25 leaf blower
Initial setting to start is 1 full turn on both low and high adjustments
Oct 07, 2014 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Bolens bl110 weedeater runs until I try to cut
Adjust carb. Initial adjustment is 1 full turn out on both low and high side. If it still fall on it's face, turn the low side out and additional 1/4 turn.
Sep 24, 2014 | Garden
How do I adjust the carb on a FB25 weedeater blower??
These need to be adjusted using a Tachnometer however to get the unit started. Turn the "L" screw in until it lightly seats then back out 1 1/2 turn. Do the same for the "H" screw. This should get the unit running then it can be fine tuned.
May 15, 2012 | Weedeater Garden
Johndeere c1200 weedeater
Clean air filter and check fuel lines for trash.If that isnt the problem your carb may have trash in it.Thanks for asking and I hope it helps.
Jul 16, 2010 | Garden
On a kazuma 50cc engine carb adj screw location
The lower of the 2 screws is the fuel/ air mixture- the upper screw is the idle adjust screw
Jan 22, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
How do you adjust the carburetor
There is probably no adjustment. They don't want ordinary guys work'n on their own stuff any more...Lol. If you are having carb. problems try this:
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 31, 2009 | Troy-Bilt Mtd Southwest Tb320bv...
My echo will start ,but will not run.
Youwill need to disassemble the carburetor and spraywith carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals canbecome blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 21, 2009 | Echo Garden
Garden Logo
506 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
