Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Mod: 10651262103, icemaker leaking, not making ice
Mod: 10651262103,Kenmore fridge icemaker leaking, not making ice properly, how can I fix this myself.
Thanks
  • Kenmore Master
  • 4,655 Answers
We need to know if the ice maker overflowed or if there is a crack. Sometimes the water gets frozen in the fill tube and diverts the water everywhere other that ice maker. Rare but sometimes something causes the water control valve to stick open on rear of refrigerator. Your ice maker has a thermostat inside it and starts a cycle when the thermostat says the water has frozen. That starts a cycle of about six thing to happen.The defrost element below ice maker warms the bottom just enough to loosen the ice. Micro switches feel and sense the position and as it nears ending the final step the ice maker tells the water control valve to open for a few seconds. An adjustment in that control may stop over flow. But if cracked in a major section it will need to be replaced. Let me know if this helps you. Sea Breeze
Posted on Jun 20, 2009
  • John Tripp
    John Tripp Jun 20, 2009
    Yes you can fix it yourself. Sometimes it is cost effective and sometimes its not. Do you know where the leak is and would you like to compare the parts and cost of replacement?
    http://servicepartstec.blogspot.com/
Kenmore 795 leaking water behind ice maker
I would first check the hose that brings the water from the pipes in the house up into the icemaker make sure that's not leaking. Then I would check all of your connections, Making sure they are good and tight and that there's no holes either in the copper line or the poly plastic line. If all of that checks out fine and you have no leaks there then I would investigate the icemaker.
May 27, 2018 | Kenmore Refrigerators
I have a Knmore side by side fridge, model 106.55606400. The ice dispenser have stopped dispensing ice. The icemaker working fine,the dispenser motor makes a sound when lever depressed for ice.Where do I...
One is the icemaker will leak on the auger motor and freeze it up as you describe. If this is the problem the ice will be very solid (hard ice). If this is the case check to see if the tube that feeds the icemaker water is clogged with ice and if so remove the ice and replace the water valve. If not the icemaker may be overflowing, which is still most likely due to a bad water valve.
The other thing that will cause this is an air leak. If it is an air leak the ice will be frosty more like snow than hard ice. But even so it will still cause the auger not to work. If this is the case check the little flap that opens and closes to let ice through the door to see if it is closing properly. Then check the door gasket to see if it is sealing properly.
Turning the temp. down shouldn't help nor hurt your problem.
Jun 08, 2011 | Kenmore Refrigerators
I have a Kenmore Coldspot Model #78187891, with a leaky icemaker problem. The icemaker seems to leak near the front of the icemaker (closes to freezer door) and makes these stalactite structures. This...
Most likely ice maker is the problem and would need replacing. Water valve is letting to much water in but the amount of time solenoid stays open is controlled by the ice maker
Sep 28, 2017 | Kenmore Refrigerators
Ice maker issues - what to do next?
I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore elite fridg that is not making ice,but i have water at the door. modle # 50509990. THANKS.
Pour about 2/3 cup of water into icemaker ( if there is no cubes in there now ) . If the icemaker dumps the cubes when frozen , replace the water valve . If it doesn't dump , replace the icemaker . Also make sure the coils at the bottom of refrig in front , are clean of dust , lint , pet hair , etc . Also check the plastic hose inside the freezer , to the icemaker , to make sure it is not frozen . If it is , replace the water valve , due to slow drip leak .
Sep 05, 2009 | Kenmore Refrigerators
The icemaker leaks water from the fill tube into the fridge
my suggestion is to start from the beginning! shut down the fridge for a couple of days store food somewhere else (obviously and see if you get much water at bottom. have mos and bucket nearby. blow into any hoses that are accessible. unplug fridge of course.
Mar 18, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ice maker not working properly
Make sure the fill tube going directly into the icemaker is not touching the part that receives the water, if it is touching the water will spray all over and not go into the cavity
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Fridge Leaking
the icemaker can overfill causing water to run over into the freezer
the fill cup on the back of the icemaker could be frozen letting the water overflow into the freezer
if the fill cup is not frozen then you need a modlue for the ice maker if it is whirlpool built, if ge or frigidaire design then replace the icemaker
May 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker puts to much water
First give me the entire model # on the sticker inside the fridge so I can help you.  We can solve this one.
Oct 18, 2007 | Kenmore 53642 / 53644 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
241 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
