Question about Dell Inspiron 1525 Notebook
Inspiron 1525 plugged in not charging
My Inspiron started doing 1 month after the 1 year warranty was up. Dell has already replaced the AC adapter once, and I bought a 170.00 battery because thats's what Tech Support said would fix it. I finally took it do a repair shop that said it is not recognizing the adapter all of a sudden, and that replacing the motherboard is the only thing that will fix it. (He also tried the suggestions that others had made on the internet.) Is this Dell's way of getting up to buy new computers? I might as well if I have to replace the motherboard. Also, would purchasing a daughterboard have any effect? They're a lot cheaper, but if this would work, I'm sure Dell would never suggest it. Thanks for any help.
  • 130 Answers
Replace u r computer, as the cost of mother board and the age of your computer I suggest replacement.
Posted on Jun 21, 2009
I have a Dell Inspiron 1525. I bought it in August, 2008. It has been working fine until recently. Now the problem is that it only charges upto 32%. and then it says "Plugged in, charging" but it does not...
How long does the battery last, when you use your computer WITHOUT the AC adapter connected?
Did you purchase a 1-year, 2-year, or 3-year warranty?
If the latter, you could exercise the warranty, and get the battery replaced.
Do you have any friends with a compatible laptop?
Does their battery charge to 100% in your computer?
Does your battery charge to 100% in their computer?
Have you looked on eBay to purchase a replacement battery?
Or, there is a company in Seattle that takes your battery,
opens it up, replaces the cells, closes it, and ships it back to you.
This could be less expensive than buying a new genuine-DELL battery.
Sep 01, 2010 | Dell Tablets & eReaders
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery not charging
Take out battery & place it again.
If does not charge again, contact sevice centre.
Apr 16, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Hey i had my dell inspiron 1525 for quite a while and now the charger stopped working for some reason. i need help
The charging circuit requires an ac adapter with an intact sensing pin in the center of the Adapter barrel plug that connects to the computer. If the pin is bent or broken, the charger is disabled.
If possible, try a known good adapter from another D or E Series Dell Portable. If a KG adapter charges the battery, replace the adapter. If it makes no difference, then replace the motherboard
Jan 22, 2010 | Dell Inspiron 1525 Notebook
Does it mean that my battery on the Dell Inspiron 1525 is out if it won't charge anymore. It also won't work when the battery is removed and the AC adapter is plugged in
It's not the battery than. If you ask me - two possible problems:
1) The AC adapter is shot to hell and you need to replace it
2) The motherboard input plug is damaged and you need to service it.
Further diagnosis:
Test the AC adapters output plug with a voltage meter (if there is nothing than that's the problem, if you get a positive reading - its fault nr 2)
You can also try to borrow a AC adapter of a friend (only if it's the same model) and plug it in.
Best of luck.
Nov 12, 2009 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 Battery won't charge
i recommend you to buy new one.. for dell 1525 .. must better
Jun 08, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 will not charge the battery
CHECK IN YOUR BIOS AND MAKE SURE ANY SETTINGS FOR POWER ARE ALL CORRECT ...SO THAT WOULD BE A F2 FUNCTION IF THE ABOVE IS CORRECT ...SEE IF THAT SOLVES THE ISSUE .
Jun 02, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron will not work on Battery.
At the very minimum its your battery. The other side is that it could be your power utility inside your laptop. Lets try getting a new battery first.
Note: Try a different AC outlet first.
Mar 12, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Notebook Logo
547 people viewed this question
Alun Cox
