Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
Coils freeze, no water in collector. Model AD7ousso
After running 4 hours, the bottom 2 coils ice up and no water collects in the container below.
  • 148 Answers
Needs to be charged with freon
Posted on Jun 21, 2009
Moisture collecting at the top front when running, even at mid power, over the control panel, sometimes turns to ice. if I shut it off when it is doing this the problem stops for awhile
Well, sounds like you have a good cold section in the dehumidifier-- that is good!-- But I agree-- we don't want water condensing on the surface-- and we surely don't need it turning to ice!
A couple questions to help us get to the next level of trouble shooting this problem:
1.) How cold is the room you are running the dehumidifier in?
(Obviously-- the warmer a room is, the easier to remove moisture--
the colder the room, the easier to drop the air temperature well below the freezing point-- making ice.)
2.) Have the air filters been cleaned/changed recently?
A dehumidifier needs a steady fast moving supply of air across its whole condenser/evaporator surface, in order to remove the maximum amount of water from the air, and not freeze up. (I would winder if something isn't blocking the flow of air toward the top of the coil?-- so that the coil in that area is going well below freezing temperatures, and thus allowing water (or ICE!) to develop near the top of the coil?-- Can you check air flow for us?
3.) You have suggested a good solution,-- especially if the above problems can not be easily corrected: Turn off the unit every few hours, and allow the warmth of the room, to defrost the coil....
In fact-- just to make sure that the air flow is not being restricted by ice deep within the coil-- let it stay off over night-- or bring the dehumidifier into a much warmer room, to make sure no ice is still blocking air flow deep within the coil..
Let us know what you learn about air flow, and get back with us-- THen maybe we need to take the trouble shooting deeper insicde the device.
I hope this helps-- MB
Aug 22, 2013 | Comfort-Aire BHD-301 Dehumidifier
My LHD45ELY7 freezes up. Why? Is it broken?
Assuming this isn't just a weather change, it probably needs cleaning. The unit is supposed to run the fan without the compressor intermittently to give the cold coils a chance to warm up a bit so the little bit of ice that normally forms can melt off. But once they get dirty, this melting and runoff is impeded. Spray some formula 409 (or similar) on the coils and rinse thoroughly. It is also possible that the unit is not switching over to run the fan only (without the compressor). This could be due to a bad temperature sensor, or it may be dirty or corroded so it thiinks the coils are a bit warmer than they really are. If you can find this sensor (it's usually attached to the coils with a little spring clip) see if you can't clean up where it makes metal contact (thermal contact) witht the coil. Good luck.
Oct 14, 2012 | LG LHD45EL Dehumidifier
When the dehumidifier runs it forms ice on the top of the unit and does not collect much water in the bottom.
The problem you described can be caused by 3 things:
1. The air intake filter is dirty or clogged and needs to be removed and cleaned.
2. The cooling coils are dirty and need to be cleaned. Turn the unit OFF & unplug it before attempting
to clean the coils with warm water and mild dish washing liquid. Then rinse and wipe dry. A light
coating of WD40 will help them stay clean.
3. The dehumidifier is being operated in a basement, where the air temperature at floor level is
below 65 degrees. When this happens dehumidifiers struggle at temps below 65 degrees F
unless it its a Low Temp model, designed for basement applications. Raising the unit up off
the floor onto a sturdy table or counter top, that can hold the weight of the unit, plus a full tank
of water, will generally resolve this problem.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 09, 2011 | LG LHD65EBL Dehumidifier
Dehumidfier runs, collects little water, the coils freeze up and water leaks out
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Jun 23, 2011 | Kenmore 53509 Dehumidifier
Our dehumidifier has formed a sheet of ice amongst the coils and will no longer pull moisture from the air. The hole from which the water drips is completely iced over. It is 70degrees in the room and...
Turn the unit OFF and unplug it from the wall. Allow it to thoroughly thaw and remove the humidifiers cabinet to expose the cooling coils. Clean those thoroughly and coat with a very light coating of WD40. Reassemble the humidifier and turn it ON. Set your humidity control at 50% and allow the unit to run for at least one hour. Check for water collection in the bucket and for any signs of icing, after one hour. If water is in the collection bucket and no signs of icing, lower the humidity to 45% and continue. If you not any signs of icing, watch the unit, as you need to know if it automatically goes into defrost mode. The compressor should shut off, but the fan will continue to run until defrosting is completed. If it doesn't the auto defrost sensor has failed and will need to be replaced.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
May 08, 2011 | Dehumidifiers
The coils freeze up after less than a half hour of running. It does not matter what humidity setting I use or if I select the 2 hour or 4 hour run cycle. B/c the coils are freezing up, the dehumidifier...
the coils freeze up for one of two reasons .. if air flow is blocked .. sometimes by dust buildup or fan bearings needing lube .. second if the fan is working properly then ice buildup can be caused by low refrigerant levels .. the proper charge produces a steady coolness across the entire evaporator (cold coil) .. as the level drops it tends to cool a small part of the evaporator way too cold .. that creates ice .. the ice blocks the air flow and soon the whole thing is blocked ...so check the fan first .. if its running properly and there is nothing blocking air flow then suspect low refrigerant.. that requires adding a saddle valve service port to the system to allow adding refrigerant .. often the problem is caused by the fan not working at all because of lack of lube in the bearings or a bad starting capacitor ..
Aug 15, 2010 | Goldstar DH504EL Dehumidifier
Dehumidifier problem
First, make sure the rectangular filter on the back side is clean so air can flow over the coils freely. Try to place the dehumidifier on a table or something to get it off the floor. (floor level is cooler than head level) If you still have icing issues, replace sensor. (part # WK23X10011 )
Sep 01, 2008 | Dehumidifiers
Running but not collecting water...
Dehumidifiers have only a few components, and operate on the same principle as a refrigerator, freezer, or air-conditioner.
Components Residential dehumidifiers have a cooling system made up of these primary components:
  • The compressor is the quiet motor (engine) of the cooling system. It's the black, football-size component at the bottom of your dehumidifier. The compressor runs as long as the dehumidifier humidistat (the humidity-sensor) calls for a reduction in the humidity.
  • The condenser is a series of finned tubes, similar to a radiator. It's usually near the circulating fan.
  • The evaporator is located near the back of the dehumidifier, right above the water-collection container. It also resembles a radiator or a coiled-up set of tubes. When the dehumidifier's humidistat senses increased humidity, it cycles on, which starts the compressor and circulating fan.
  • The circulating fan circulates the air over the evaporator and condenser coils.
Principle When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
Jul 29, 2008 | Maytag M7DH65B2A Dehumidifier
Dehumidifier does not collect water
The only thing you really need to check is that collector coil that the the water is supposed to condense upon, much like the "sweat" on a glass of ice water. If that collector coil is not nice and cold, then your machine needs freon or has some other serious problem.
Aug 04, 2007 | GE AHG40LA Dehumidifier
Does not collect water
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
611 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
