Question about U-Line 15R Compact Refrigerator
Fans do not run. Interior light flickers. On the power board are two lights; one red one green: the green one flickers and the red one flashes on and off very rapidly. The fuse is in tact. It does not cool. What do I replace?
  • arcandmore Jun 23, 2009
    As stated in the first inquiry, "The fuse is intact".. That means it has not, "blown", it is good. I have checked all connections to the power board and found them snug and apparently making good contact. Anything else before I replace the power board?
  • 495 Answers
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Posted on Jun 23, 2009
    Scholar:
  • 174 Answers
There is possibility of loose connection in the circuit, possibly on the power board for which the current doesn't flow to each points successfully. You need to verify the power board circuit. Look for the fuse and wiring for replacement.
gud luck.
Saumya.
Posted on Jun 20, 2009
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Sony kdf-e50a12u my tv flashes the green power light only
How may flashes the LED does? This error code will tell you what is the problem.
Aug 02, 2017 | Sony KDF-E50A12U 50" LCD HDTV
TV just turned off while watching. standby light flickering red 7
Ur power board have dead capacitors.U Know how to solders?Take the tv aparts,check these capacitors in the power board for dead capcitors like puff up or burst open.Replaced these capacitors to get power back.Or buy and replaced the whole reburbish power board at Shopjimmy.com,Ebay.com.
Jan 21, 2010 | Televison & Video
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
U-Line 15R Compact Refrigerator Logo
110 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Marvin
Marvin
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
