Question about Briggs and Stratton 020275 Elite Series 3400 PSI Portable Gas Pressure Washer
Pull start locked up
Ellite series pressure washer pull start handle is locked up, won't extend more than 8 inches
    Loyalty:
    Visited the website for 30 consecutive days.
  • Briggs Master
  • 1,495 Answers
Take the housing off and see if you can free it up if not you will have to take it apart and rewind
Posted on Feb 06, 2018
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
Pressure washer won't start. It has gas, oil and I turned the switch to turtle and to rabbit position. Does it matter if water is on first or not? It won't start either way.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Aug 22, 2011 | Briggs Stratton 020273 Elite Series...
Pull start won't pull. Engine was running then stopped. Now the pull cord won't extend
First. Turn off the water....Release all of the pressure off of the hose and pressure washer. Try and pull again. If it still won't pull check to see if there is oil in the engine. The engine may have locked up.
Feb 12, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Jun 03, 2010 | Mtd 22" Yard Machine Push Mower
Starter cord wont pull
Try removing your spark plug, you could have fuel on top of the piston or even "vapor lock". If that doesnt work try squeezing the trigger of gun/wand as you pull.
May 31, 2010 | Honda Pressure Washer PSI 3000
Machine will not start
THE MOST COMMON THING WITH THIS WASHER IS THE LID SWITCH. THERE IS A TEMPORARY & EASY WAY TO FIGURE THIS OUT. FIRST OPEN THE LID. LOOK AT THE BOTTOM JUST A LITTLE RIGHT OF CENTER WHEN THE LID IS UP. DO YOU SEE A LITTLE WHITE PLASTIC PIECE? THIS IS THE STRIKE FOR THE SWITCH. IF IT IS MISSING YOU NEED THAT. IF IT IS THERE LOWER YOUR LID SLOWLY UNTIL CLOSED ALL THE WAY. LISTEN TO HEAR A CLICK WHEN DOING THIS. A CLICK WILL DETERMINE IF THE SWITCH IS BEING ACTIVATED AND THE POSSIBILITY THAT IT IS GOOD. IF YOU HEAR THIS CLICK AND THE WASHER WILL NOT START THEN YOU MAY HAVE A TIMER ISSUE. IF YOU HAVE NO CLICK THEN CONTINUE. UNPLUG WASHER. REMOVE THE 3 SCREWS AT THE TOP OF THE CONSOLE. WITH ONE HAD ON THE CONSOLE TOP CENTER STARTED TO PULL FOREWARD. PUSH BACK AT THE BOTTOM CENTER WITH THE OTHER HAND. THE LID SWITCH HAS 2 RED, 2YELLOW, 2 WHITE AND 1 BLACK WIRE TO IT. UNPLUG THIS. ON THE BACK LEFT CORNER OF THE LID SWITCH THERE IS A LOCK TAB. WITH ON HAND LIFT THE WASHER LID UP 3 INCHES OR SO. WITH THE OTHER HAND LIFT THE LOCK TAB ON THE LID SWITCH WHILE PULLING FOREWARD ON IT. PUL LID SWITCH OUT AND PUSH THE PLUNGER IN. DOES IT CLICK? IF YES THEN FIND A VERY TINY SCREW TO SCREW IN THAT END OF THE PLUNGER. YOU ONLY NEED TO EXTEND THAT PLUNG LESS THAN 1/8 TO 3/32NDS OF AN INCH. YOU CAN ALSO GLU SOMETHING TO IT. REASSEMBLE ONCE THIS IS DONE.
Apr 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Cannot pull start pressure washer. Cord will not
cord will not extend past 3 inches; just shut down after last use after 30 seconds.
Aug 31, 2009 | Garden
Finding Lint Filter on Kenmore 70 Series Model 110
I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
Apr 19, 2009 | Kenmore 22422 Top Load Washer
Whirlpool Duet Front Loading Washer Won't Turn On
mains filter blown door lock fail main pcd fail appliance doctor
Jan 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Briggs and Stratton 020275 Elite Series 3400 PSI Portable Gas Pressure Washer Logo
370 people viewed this question
Top Briggs Garden Experts
Mike
John Trevino
Marvin
Marvin
Are you a Briggs Garden Expert? Answer questions, earn points and help others
