Question about Garden
Lawn mower will not start i put fuel in the oil housing by mistake drain it all out and now it does not run
  • Jim Parker
    Jim Parker May 11, 2010
    Did it run before this all began?
    Jim
  • 84 Answers
Try flushing the oil and let it dry out but make sure you use the nut on bottom of lawn mower so you don't get any liquid in the cylinder. also try cleaning the cylinder.
Posted on Jun 24, 2009
I can get my lawn mower to start but it will not stay running
Drain all the gas out of your fuel tank via fuel line to carburetor. Then remove the bowl under your carburetor, place container under carb first. You will see that you have water in your gas. Just a little would keep your mower from starting and running. GOOD LUCK FRIEND.
Sep 21, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Hayter spirit 41
Drain tank, flush with gas. Remove float bowl from bottom of carb and clean. Fill tank with fresh gas and Stabile. Prime 3-5 times. Pull rope 10 times to start.
May 27, 2013 | Garden
Starting
Pull the air cleaner and check for obstructions, dirt, oil etc.
Leave off and try to start.
Check plug for oil or wetness from fuel. Have a spare handy to check for spark.
A shot of instant start into the air cleaner housing might help if the mower has bad or old fuel. You should drain the fuel out if it over a month old and unpreserved.
Also, if the mower has been sitting with fuel in it the main jet sometimes gets clogged up due to todays alcohol enhanced fuels. You should get some help with removing the main jet and cleaning it out.
Jan 19, 2013 | Husqvarna Rear Propelled Rear Bag Lawn...
Engine wont run with wrong fuel mix
drain the fuel and replace with fresh fuel if you cant get it started you might need to replace the spark plug
May 03, 2012 | Briggs & Stratton Garden
I bought a craftman lawn mower 6.75hp. I only used it twice, and then I let the lawn mower set in my garage for about 6 years, with the gas and oil in it. Now it won't start, and I did get it to start...
If it has been stood with the same fuel in it for any lenght of time, then the fuel will go bad, drain the fuel and re fill with fresh fuel, if there is a bowl drain on the carb slacken this and drain the bowl, now try again, if it does not sort itself out after a lenght of running then will need to remove the carb float bowl and blow an air line through the jets.
Feb 29, 2012 | Craftsman Garden
I put too much oil in my lawn mower and when I start it up it smokes
Hi patsy hale...
You need to drain the over fill of oil out of your mower, if not it could damage the engine, if it has not already done so.
If you have a drain plug it will be on the bottom of the engine under the mower housing.
Remove and drain out until you reach the right level the oil should be at.
If you do not have a drain plug under the mower then you will have to tip the mower over on its side with the oil fill plug out and drain the excess oil that way till you reach the proper level.
I hope you have not done permanet damage already, if it still smokes after a a few minutes of running then you do have major problems.
Please take time to rate me
Sep 01, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Put too much oil in toro lawnmower
Hi cldgaines1...
You do not want excess oil in the crancase, it can cause mechanical problems and smoke a lot.
Drain the excess oil out of the crankcase..
If you have an oil drain it will be located under the mower housing.
If you do not have an oil drain then you will have to tilt the mower with the oil filler plug removed to drain the excess oil from the crankcase.
Please take time to rate me.
Jun 27, 2011 | Toro Power Lawn Mower
Lawn mower runs and then putters down, won't die but runs slow.
clean the air filter,wash out in turps if foam type,then wash in soapy hot water,then rinse,let dry,then put litle bit of clean engine oil in it,squeeze.drain all fuel,and put fresh in.may have to pull carb to bits and blow out,and reassemble.put new spark plug in.is it a briggs engine,or tecumseh?
Jul 11, 2010 | Garden
Lawn mower cranck but wont start...
Since you already checked for spark and air I would drain all the fuel out of it and check that fuel for water. Over time some lawn mowers end up with contaminated fuel. You can see the water sitting on the bottom of the fuel if you let it stand for a bit in a small plastic bowl.
Be sure to empty and dry out you fuel can as well. Especially if the mower stopped running right after a refuel. Which is a good sign your gas can is contaminated too.
Jun 26, 2010 | Poulan "Poulan" Push Mower
Lots of smoke and oil comming out the exaust . only 1 and a half year old
Has fuel with oil accidentally been mixed to the fuel for this mower? We have had mix oil accident get added it to this lawn mower and it will smoke a lot with 2 cycle oil.
Unless you are certain no oil is mixed with the fuel I would drain and clean the fuel system.
Replaced the spark plug with the new and replace the air filter In addition ensure you do and oil change every 30 hours using a high grade 30 wt oil to include make sure it is not over full.
Hope this tip helps.
r/
David
Feb 06, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
