Question about Sylvania 6420FB 20" TV
I need to adjust the color on my Sylvania 642OFF tv.
I don't know how to get to the color adjustment feature of the tv.
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: cant locate or adjust the the TV color
Sorry to tell you my friend, if you do not have the original remote, you cannot adjust the set with the on screen menu. See if a friend or someone you know has a sony tv set that you can borrow one from. Sony does make a universal inexpensive remote I saw at walmart once. That should work too. Good Luck Please dont forget to rate this thread.
Posted on Nov 06, 2006
SOURCE: my TV is blurry. I
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is ....picture becomes dull...blurr... (less brightness & less contrast , no clarity ) ........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture after switching TV --- this adjustment is very important ) ---------- iam from bangalore ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact good TV service engineer ------- because they are highly experienced & can fix this component very easily ( or if any of your friend who is in servicing line can do this ) - 100% GUARANTEE again your TV works normally - GUARANTEE
Posted on Jun 18, 2011
  • 74 Answers
SOURCE: sylvania tv srt2232s picture is dark. i have used
Hi
Remove back fron tv locate line flyback transformer
on this transformer there should be two adjustment controls very carfully adjust the bottom one, do not adjust to far as picture will have fine white lines on it
Posted on May 17, 2010
Testimonial: "Thank you I was able to correct the problem with your help"
I have a Sylvania Model No. SST4273 TV manufactured in 2003. For a couple years now I've noticed that I can't see the sides of many broadcasts - text extends to the left and right beyond my screen.
If there's a setting that will show the whole picture, it's in the Menu under Picture:
1)Press the MENU button so that the menu display appears on the TV screen.
2)Press the VOL(ume)  button so that "PICTURE" is selected.
3)Select the feature you wish to adjust with the CH(annel)  or  button and adjust it with the VOL(ume)  or  button.
Feb 18, 2018 | Sylvania Televison & Video
No remote for sylvania tv dvd combo how can I adjust color etc
Hello, Tom -
If you choose not to purchase a universal remote control to use with your Sylvania TV, you can probably use the buttons along one side of the TV screen to adjust the color and whatever other aspects you wish to adjust.
First, you will need to turn the TV on by pressing the Power or On/Off button for the TV. Then you will need to figure out what the other buttons on the side of the TV do. If you have the owner's manual refer to that.
Without knowing the model number of your Sylania TV, I cannot find an owner's manual for you and give you the specific directions. If you wish, using the Edit feature, you can add the model number of your Sylvania TV so I or someone else can better help you.
Dec 26, 2017 | Sylvania Televison & Video
I have a Sylvania TV Mod 642off which I have disconnected from Comcast and want to use with a TriQuest 8040 Antenna. Do I need a digital converter?
When you do a channel scan do you get any something - something channels (ex. 10-1 0r 10.1)? if you do you don't need a digital adapter.But most flat panels already have digital antennas in them.
Aug 06, 2011 | Televison & Video
I just need to adjust the resolution on this TV. NO ONE at RCA could seem to help me. Thank you.
hi,
did u mean to adjust the picture setting then go for the following
1 press menu on the remote
2. using down arrow select picture quality and press ok. available options in picture quality and its use is listed below. you can use it according to your preference.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
Sharpness Adjusts the crispness of edges in the picture.
When exiting this menu, the Save Personal Picture Preset choice list will
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
Dec 21, 2010 | RCA G36705 36" TV
Syvania 642off how can I change to frontpanel video input without the original remote?
you should be able to do it on the front of the TV with either the channel down button or a tv/video button
Dec 03, 2010 | Sylvania 6420FB 20" TV
My Tv has red light (color) out of focus..I've tried tuning the lance but it's not the problem in the lance..it's something else..don't know what..do you?
Your TV has three picture tubes which are aligned to properly converge the projected light beams on the screen. Each picture tube projects a single color of Blue Green or Red. During production your TV was carefully adjusted to properly align these colors. As a feature you have the ability to adjust these colors.thats called convergence.If you don't have a manual to show you how to adjust you can find one here http://www.mitsubishi-tv.com/support.html
Mar 03, 2010 | Mitsubishi WT-46809 46" Rear Projection...
I don't have the remote for my sylvania tv and I need to change the picture tint. Is there any way to do this manually?
Go to the menu button on the tv press it go throught the functions pick
colors,contrast,brightness,tint...adjust what u want.
Aug 25, 2009 | Sylvania SRT2319 TV
Elongated picture on Sylvania 27" Model # SRT2232S
there is a vertical adjustment on the picture tube it's the yoke as it's called but you can adjust it so much..but it does sound like the tube is on it's way out
Aug 28, 2008 | Sylvania 6427TE 27" TV
Sylvania Model 6420FF Television - How Do you Adjust Color?
Hit menu on your remote - click on picture - scroll to color
If you need a copy of your owners manual please click here
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Oct 21, 2007 | Televison & Video
Sylvania 6420FB 20" TV Logo
235 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
