Question about Briggs and Stratton 020275 Elite Series 3400 PSI Portable Gas Pressure Washer
Pull handle locked up, won't extend more than 8 inches
Passenger door can be opened from inside but not from outside...how too fix???
Remove the door lining and look inside by the lock. There is a linkage that has come adrift. To remove the door lining, remove handles, escutcheons, and arm rests. Using a wide blade screw driver gently pop the plastic rivets that hold the lining to the door.
Dec 02, 2015 | Cars & Trucks
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
Troybilt 5500 generator pull cord locks up...just had it for one year...cord was very easy to pull @ first...but lately it locks up when I try to start it...any suggestions?
your cord is too long is why its binding up ,,,on the tee hand where you put your hand on to pull,,,,take a screw driver and push up the tied knot out and away from the tee handle,,,,take and make another knot about 8 inches and pull the cord back into the tee handle then try it again. Most have a long rope, cord etc for maximum pull,,sometimes they go overboard on the length and it binds up on the rewind of the recoil system
Dec 08, 2011 | Briggs & Stratton Power Products 5,550...
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
Just installed this lock - second one we tried (first didn't close all the way) Backlite is not working. did we oversee something?
I have reviewed the on-line installation instructions for this lock, and it requires attention to detail to properly install.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
For instance, the first one may have not closed all the way if your door has a 2 3/4" setback instead of 2 3/8", and you did not extend the bolt and adjust the latch as shown in figure 2 of Step 1.
Also, if you don't run the door handling routine properly as in Section 8, the lock won't work properly.
But I believe that you are past that learning curve after the second installation, and I don't know why the backlight won't work on your new lock.
I didn't see any option to enable/disable it in the instructions. So my suggestion: If the lock is otherwise working properly such that the backlighting is the only problem, I'd give a call to the Customer Service number 1-800-677-5625 and discuss it with them. They will let you know if and what the problem is, and a new lock is certainly under warranty!
Jul 23, 2011 | Kwikset 907 90715 Satin Nickel SmartCode...
Hey there i have a paulan 446t pro extende chainsaw with a broke pull rope, i tore it apart to the point where i cant slide the outer cover off because of what i think is the clutch. which is just on the...
You should not have to remove the entire case to work on the starter mechanism. The starter assembly should come off by removing 3 or 4 screws from the left case. The cord is wound on a spool which has a coil spring inside which must be rewound CCW about 2 turns, then wedged to prevent the spool from unwinding again. Pick the remnant cord from the spool, then thread a new cord (about 3 ft.) into the hole/slot where the old cord was attached. Melt the cord end somewhat, then tie an overhand knot in the end. Wind the cord around the spool CCW until most of the cord is used, then thread the end through the exit port and pull about 8 inches outside. Clamp the cord with locking pliers or tie an overhand knot to prevent the cord from being drawn back inside. Thread the cord through the handle, melt that end, and tie an overhand knot. Pull the knot into the handle, and untie the knot used to hold the cord out. Release the wedge on the spool, and try to pull the cord as if starting--it should pull out without binding and return fully. Hope this helps!
Oct 20, 2010 | Garden
MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Jun 03, 2010 | Mtd 22" Yard Machine Push Mower
I need to find a new handle bar for the quinny buzz as the handle bar will no longer extend
Dorel UK 01842 763 281 (Mon – Fri, 8:30 am to 4:30 pm) are the UK suppliers of all spare parts for the quinny range and can supply you with a new handle bar. It's likely that the grey button (handle bar extender button) is broken. This pulls up the little studs on the underside of the handlebar allowing you to adjust. Its a fiddly job but can be done.
May 31, 2010 | Quinny Buzz Three Wheel Stroller
Pull start locked up
take the housing off and see if you can free it up if not you will have to take it apart and rewind
Jun 20, 2009 | Briggs and Stratton 020275 Elite Series...
1991 Saab 900S Convertible- How do I manually open the hood?
a 1991 900 S. does not have an automatic button to open anything with the exception of the door locks.
Jan 03, 2009 | 1991 Saab 900
Briggs and Stratton 020275 Elite Series 3400 PSI Portable Gas Pressure Washer Logo
98 people viewed this question
Top Briggs Garden Experts
Mike
John Trevino
Marvin
Marvin
Are you a Briggs Garden Expert? Answer questions, earn points and help others
