Kitchen Ranges Logo
Danielle Randall Posted on Apr 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Burning plastic smell range
You oven smells like burning plastic because you or someone didn't read the directions before you used the oven. Most likley the shipping packing was left in the oven for the racks. I do warranty work for Kitchenaid--- Most of these mistakes are customers not reading directions.
rayreidblack
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 117 Answers
  • Posted on May 08, 2014
rayreidblack
Expert
Level 2:
New Friend:
Cheetah:
Answers
117
Questions
Helped
41976
Points
129
Too true I did warranty for Miele and people often don't read the instructions.
5 Related Answers
A
Anonymous
  • Posted on Apr 01, 2008
SOURCE: Smeg Oven electric burning smell
My Smeg cooker worked fine for 5 years. Then I noticed that the fan which stays on after you turn off the oven did not ever turn off, unless you switched the oven off at the fuse box. I think this is a fan that cools the oven down, but some bit of it is now broken because it doesn't realise that the oven has cooled down. It smells funny when you first turn it on, so I don't know if that is an electrical fault smell. Model possibly 70cm A420-5, but could be an earlier model (bought in April 2000). Is double oven with 4 rings on top, 70cm wide.
Anonymous
  • Posted on Aug 26, 2008
SOURCE: Oven/Broiler Igniters for KitchenAid range KGST307
what does code F1E3 mean in a kitchen aid superba model KGST307HBL9?
Anonymous
  • 4 Answers
  • Posted on Feb 02, 2009
SOURCE: KitchenAid oven shut down during self-cleaning
I've had the same problem and have had the thermo-protector switch replaced four times. After the last time I was so ********** I wrote to the CEO at Whirpool/Kitchen Aid in Benton Harbor, MI with my complaint. Today I received a call from an extremely nice lady in his office who said that they were sending me an updated kit for repair free of charge. The part number is 9759243. She offered that this was a known problem but was limited to just one production run - my luck!
If you are having this problem with your KGSA906PSS write to the CEO at Whirlpool!
Anonymous
  • Posted on Mar 11, 2009
SOURCE: Kenmore ~ bad smell upon first use of broil function
If you pull out the drawer at the bottom of the stove, there is a brass fitting that needs to be tightened with a 1/2" wrench.
Anonymous
  • 105 Answers
  • Posted on Apr 09, 2009
SOURCE: kitchenaid selectra oven range: Electrical smell
If this is a new range the odor is coming from the binder used to install the insulation in the range. You would need to put it through a self clean cycle of at least four hours to burn off this binder. I would suggest that you do it on a nice day when you are staying home and can open the windows as it will smell quite horrid for a while.
2answers
When I turn on the broiler it smells like plastic burning
check the bottom of the oven to see what's down there and clean it out. Check the broiler coils themselves to make sure they are not coated in something. Things that smell like burning plastic, often are, which is poisonus. Also things that smell like burning plastic often cause spontanious electric fires, which are WAY dangerous. Figure it out before using the broiler again. The life you save could be your own.
Burning smell from LG oven
Hi Mike Plante, I read your problem and would be very appreciative if you can share the solution that you eventually found, as my LG unit has experienced this exact problem after the same repairs were made. Please post an additional comment on the website. Thanks, Jeff
Rubbery smell, sparks from inside back panel
Any luck with your problem from 2012? We have the same issue.
Frigidaire gallery oven purchased at Loews in October. Can't use the oven because it smells. Told the smell will burn off but after several hours of running it still smells awful. Frigidaire rep said this...
Sorry to read about your problem, I hope this helps you out.
yes lots of oil, that has to burn off... if you put it into clean mode..it will burn alot away.. plan on going out to dinner or the bar..while this is being done and leave the windows open..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
8helpful
Oven smokes and smells like burning plastic
This happened with my oven, happened twice to the same (newer) oven actually. The smell and smoke occurred both with the oven and with the use of burners on stove top. Turned out it was the main line cord which had a split. The first repair they replaced the thermol block and all the bolts holding it into place (for a total of 9 parts) the second time (about a year later) the repairman replaced the line cord and said that it probably should have been done along with the first repair. The smell coming from the oven before the repair was a toxic burning wire or burnt plastic smell. There was also smoke if the oven was left on long enough. The repairman said that the amount of heat to "cook" the connection on the line was at a fairly dangerous level. It was recommended to me by the fire inspector (who was in my unit for annual condo inspections) that it was unsafe and to have it repaired immediately. Hope this helps. Best of luck.
4helpful
Kitchenaid selectra oven range: Electrical smell
7helpful
3answers
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Gas oven smell
Have you checked the temperature with a hand held or stand alone thermometer? First thing I would do is get a cheap oven thermostat, set the oven to 200 and make sure the oven is not being controlled.
This smell, does it sour the flavor of whatever you are baking, broiling whatever?
Sounds to me the oven might be over temperature, if it checks out against another thermostat is there any breakin procedures in your manual or cd?
Check that out, next have you called the oem?
cALL EM AND TELL THEM WHAT YOU ARE EXPERIENCING, MAYBE THEY HAVE A BAD COATING,
If that goes no where, get a mailing address, ,get a frozen pancake or waffle if it is sticking to the food, cook it, wrap it hot in plastic rap then aluminum foil and mail it to them.
Once they take a wiff of it you will get some relief,
I am concerned you might have some kind gas that could prove to be unhealthy, so get this dealt with, the three suggestions above should get you an answer.
Will
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
