Question about GE Dryers
My dryer ran all night and does not get hot - GE Dryers
  • 6,784 Answers
If gas, check the following---
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
If electric, check the following--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Posted on Jun 20, 2009
My dryer has not been shutting off by itself. Last night the dryer ran all night. It should have stopped after 20m minutes. The clothes were very very warm. I'm concerned this could have started a fire....
Either the timer is faulty or the moisture sensor has failed. Do not use until you have had it checked.
What make/model is it? Hard to give advice without the info!
regards
Feb 03, 2011 | Kenmore Dryers
My env3 got wet how do I take it apart to dry it out? I laid it face down on my night stand beside a cup of ice water. The ice melted and ran out on the night stand and my phone has water in the key board...
I wouldn't take it apart, I would just take the battery and battery cover off and use a hair dryer on medium heat and blow it inside and on the outside, don't let it get hot though, just enough to dry it.
May 28, 2010 | LG enV3 VX9200 Cell Phone
I have a GE dryer that is approx. 5 years old (not sure what model). This weekend it stopped blowing hot air (just runs cold for the alotted time on timed dry cycle). It ran all night the other night when...
without knowing the model... your first safe bet is to trace the lint trap all the way to the vent and check for blockages. this will cause the effect you are talking about. also i would consider the heating element has gone bad.
Oct 19, 2009 | Dryers
My kenmore dryer ran all night and now won't turn back on
I'm not sure of your particular dryer, but most dryers have some sort of "thermatic" switch. It is designed to turn the dryer off if it gets too hot. Your's could be stuck in the open position telling the dryer it needs to cool before restarting. A simple fix may be all you need. If you remove the top, then the front panel,,, on the lower right side you should see a small semi-round disk with wires on it. with the power off,,, Gently tap on it with a large screwdriver handle and you should hear a click meaning it has reset and you should be back in business. If not, then it may need replaced. but it could also be the main motor has died. Have it checked with a voltmeter. Hope this helps.
Oct 13, 2009 | Dryers
Dryer was on energy saver setting and ran all night without shutting off and never got hot
Probably blown thermal fuse. Possibly the operating thermostat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 07, 2009 | Roper REX4634KQ Electric Dryer
Dryer gets hot runs for 10 min, then cools off
Make sure the hot air vent to the outside is clean and has no more than two 90 deg bends in it.
If the vent tubing is restricted, the system will shut off the heat source to prevent a fire.
Make sure you take it apart and thuroughly clean it.
Good luck.
Regards,
Jul 04, 2009 | Dryers
Wont start after running all night without shutting off
Bad timer, When the machine just runs and runs and runs, or runs for a very short time and shows that it ran the whole cycle but the clothes are still wet then the timer has gone bad and needs to be replaced. IF you go to repairclinic.com. You can order the timer from there or your local appliance repair company. They are around 40 dollars and you can replace the part fairly easy
May 20, 2009 | Dryers
Whirlpool electric dryer ran all night and won't heat
Yes it will heat. The two are normally not dependent on the other. The element could be bad. Check the breaker first, then the connections in the back, then the element. The timer could be bad itself allowing it to run all night. This could be a blessing in disguise as the clothes would have been damanged possibly from all the excess heat.
Dec 26, 2008 | Whirlpool LER4634J Electric Dryer
NO HEAT
CK IF YOU HAVE 220V COMMING IN OR THE HEATING ELEMENT IS GOOD. OR CK THE THM FUSE.IS NO GOOD. BUT IF DRYER RAN OVER NIGHT AND DIDNOT TRUN OFF YOU HAVE TIMER PROBLUM. THE DRYER SHULD TRUN OFF EVEN YOU HAVE HEAT IN THE DRYER OR NOT.
May 03, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
633 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
