Question about Sony Handycam CCD-TRV107E Camcorder
TR5 65E Cassette jammed , door half open
  • 790 Answers
try to inspect the mechanical lock! or maybe you have some debris or some solid matter not part of your handycam, inside the mechanical cassette that why your door not open.
Posted on Nov 03, 2007
Cassette tape has jammed inside while playing, and the cassette door will not open...suggestions of how to open the door - without dismantling / destroying the unit - much appreciated. Thanks.
This is a messy situation - I've had a few. The best thing to do really is take it to a repairers where they will be able to retrieve your cassette without damage to it or the deck.
Sep 26, 2011 | JVC UX-D66 Shelf System
A cassette has jammed close the A door of my Sony TC WE675. How do I clear the jam? The tape is probably keeping the door closed.
Please click HERE so that you will be directed to the site where you can troubleshoot the issue.
I hope that this will work for you.
Aug 08, 2011 | Sony TC-WE675 Single Cassette Deck
Cassette deck will not open
It could be three things: 1) This can occur for when the image reading head of the camera is dirty and dusty, and the rubber rollers that drive the tape get contaminated as well. Either can result in the tape itself becoming caught on a rubber roller, (it wraps around the roller 10 or so times because the roller is driven by a motor) until the tape rolls expand the rollers outer diameter until it jams, and then jams the opening lever, or mechanism.
Fixing is difficult, as access to the (usually 2) screws that connect the cassette holder to the opening mechanism may only be accessible when the door is open. Look under stickers or plugs on the front of the door, and if the screws are there, carefully remove the door and unwind the jammed tape. Your cassette will play again after you clean the rollers and heads with a suitable cleaning kit from the supplier, but there will be image damage when the crumpled part of the tape gets played.
Be aware that forcing the door will usually snap the tape
which would then require re-splicing back together, and
it can also damage the heads and roller, but sometimes sacrificing the tape and taking this risk may be the only option.
Possibility 2) The internal 'door release clip' may have bent, broken or snapped a spring. Try toggling the 'open' button (if it is a mechanical buttonl) whilst gently prising open the cassette door with a thin knife. 3) If all buttons are electronic press buttons, try fresh batteries.
Failing all the above, consider a full service from your service depot or store.
Apr 07, 2010 | Canon MV600i Mini DV Digital Camcorder
Jvc rv-b99 cassette door jammed
You need to take the unit apart. If you pull hard to open the door, you`ll break the plastic connector that moves the head up and down.
Apr 02, 2009 | JVC RV-B99GY Cassette Boombox
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
Paper jam from optional cassette
you are giving us assistance by money why i tell u the solution the way i solve my problem.
May 22, 2008 | HP LaserJet 9000n Printer
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Machine just shut off when opening the cassette door. Locked up!!
look for a tiny pinhole and insert a pin while powered up to reset the device
May 27, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Sony Handycam CCD-TRV107E Camcorder Logo
149 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
