Hoover PE235 has no power tryed changing fuse but no joy was working fine no strange noises or anything.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 17, 2010
Hoover 1200
Remove all excess water by draining to a bowl. Clear filter and drain pump blade and all will be fine.
Jul 15, 2012 | Hoover Washing Machines
Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Nov 09, 2009 | Washing Machines
Grumbling noise when spinning
This could be the bearings on the way out. Need more info. Bearings is a time consuming job best left to an engineer. Cost about £130 all in.
Aug 04, 2009 | Hoover PE235 Front Load Washer
Water filling the drawer but not going into the drum, maybe blocked with soap powder tried unblocking with a rod no joy....
Yes there is a blockage in the drawer.Try removing the lid after unplugging the power,and you may be able to reach down the front and squeeze the dispenser hose a few times may break up the soap.
Adrian
Jul 06, 2009 | Hoover PE235 Front Load Washer
Loud noise on fast spin
The drum must be removed to get at it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Arallen73@tiscali.co.uk
Sounds like you have a blockage in the filter or the motor brushes have worn down.
Adrian
May 24, 2009 | Hoover PE235 Front Load Washer
Hoover washing machine front loader, has power, have reprogrammed, but still won't start. Door lock light won't come on. For the last few washes before it quit altogether, the time lapse between pressing...
Hi brennanjodi
I think your door interlock needs replacing. Turn off the power undo the front of the door gasket and that will get you to the lock mechanism. They're about £20 to replace.
Adrian
May 14, 2009 | Hoover PE235 Front Load Washer
Washing machine problem
Sure you need to lubricate. But change the belt, you get all sizes easily. The wiirring noise is usually when the belt is off, worn out likely.
Pl rate, thanks
Dec 27, 2007 | Hoover PE235 Front Load Washer
Hoover pe235
Contact Hoover, they should be able to supply you with a new dial for not a lot of money. Warranty won't apply as it wasn't their fault. Good luck.
Dec 01, 2007 | Hoover PE235 Front Load Washer
Hoover PE235
stock is the dangerous condition for mechanic parts, knock the water in take with a plier not to strong but strongly do this when the humming sound, check for cloged hoses too..good luck
Aug 10, 2006 | Hoover PE235 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
