I put my head phone in my phone with music on but my music is not playing through my headphones! it playing through phone
SOURCE: Musit volume too loud through headphones
Download mp3gain (freeware) and it will adjust the volume in all your mp3 files down to a reasonable level. Try 84 dB. Then sync them onto your phone.
SOURCE: I plugged headphones into my
I think you just plugged an over size headphone jack...
OK, play music and try to plug and unplug several times.
if sound heard form phone just leave.
otherwise get replaced the headphone socket.
SOURCE: music from my dare only plays out of one headphone
To reset it just reverse what you did before it went out, example, headphones plug in and it comes out real quick now theres no sound, turn off the phone and plug the headphones back in and turn on phone with headset in 3.5mm jack then unplug after phone has fully rebooted and ready for use.Trust this works cause i ve done it a many of time since i hooked it up to my car to listen to music. ps did you know you can change the sound effects under the menu while the music is playing to different types of bass levels.
SOURCE: when I plug my headphones into my lg rumor phone
With some headphones, the sound will only play in MONO, or one channel (Left or Right).
From what I've researched, LG has headphones that will play MP3's in stereo (both L & R channels) provided the music files have been created so that they play in stereo.
You may want to look into buying a pair that's intended for the Rumor phone, or else recommended by LG.
SOURCE: Headphone jack not working
Hi Friend,
The problem is with your head phone it may not correctly connected,kindly check it out or replace with the other headphone and check it.
Check and revert back
Thanks for using Fixya
Regards,
Ayyasam
