I have a 50 inch Pro Scan Projection TV that was bought in 1995. I was just watching tv yesterday, everything was fine. All of a sudden when I changed the channel the picture became blurry like it had a slight double picture and the picture also took on the appearance as if I was watching the tv through a drinking glass, kind of concave in appearance. I immediately thought it had something to do with my Verizon Fios since I have had problems with just this tv (which has the main verizon dvr box) and so I do what I normally do, pulled all the plugs, etcetera. When that didn't work, I called Verizon. After about 50 minutes with them on the phone while they manipulated my box through satellite (they also had me put in a dvd and the picture did not clear up)nothing changed and they told me something was wrong with my tv. I am still not 100% positive this is the case because of an earlier incident when actual verizon techs came to my house and had me convinced my tv was bad, and it turned out to be the Fios. However, I am starting to think it may be the tv. What do you think it could be, especially when it happened so quickly with no preview of what was about to happen? P.S. There was no storms or anything else going on other than I described. I literally just went to click on another channel and, presto, picture shot!
  • 668 Answers
If this set is a PTK169 chassis, you could have bad tuning capacitors in the horizontal for the Horizontal yoke return and pincushion circuit. I would suggest that only a professional diagnose and repair it due to the circuit it is.
Hope this helps,
Skyassoc
Posted on Jun 30, 2009
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
I have a 50 inch Philips Magnavox LCD TV. It worked fine till the power went out this morning. Everything came back on fine except for my TV. It still receives a signal but it has no picture and no...
The projection bulb came on,but didn't stay on mean the bulb have problems,dosen't mean projection bulb it still good.First must replace a new projection bulb to make sure for the elimation for the projection bulb is the problems.These DLP tvs require new projection bulb every 1 1/2 or 2 years by watching the tv like 4 or 5 hours daily.So there no lost there for trying a new projection bulb alway can save it for later use.The secound could be the board that call the Ballast board have problems too.The Ballast board only job it is to ignite to the projection bulb and make it work.Replace the Ballast board too,if the tv new projection bulb react the same way.
Mar 23, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a 1994 50ex8k hitachi rear projection tv that wont turn on
it has a built in safety. there's a problem with tv board
May 31, 2010 | Hitachi Televison & Video
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
May 02, 2010 | Pioneer PRO-200 60" Rear Projection...
TV tries to power up but can't
bad lamp, yes it will not have no sound,
Jun 08, 2009 | Panasonic PT-50LC14 50" Rear Projection...
I have a sony bravia 50 inch rear projection tv. model KDFE50A12U .It has been working fine with no hints of a problem,yesterday when i switched it on the power light started to flash and the fan,bulb and...
i have a sony bravia 50 inch rear projection tv kdf 50e2000 the problem is it fail to switch on when it did it swicth on had black line cross the screen
Apr 01, 2009 | Sony Televison & Video
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
Samsung HL-R5087W 50 in. green tint
usually that means you have external speakers to close to tv and magnets in the speakers do that
Apr 17, 2008 | Samsung HL-R5087W 50" HDTV-Ready...
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
