I have a GBV441 DVD/VCR player which is shaky and plays the DVD in an overall green color which distorts the image. I have tried to adjust the color, but this doesn't work. I've tried it on 3 DVD's and they all have the same problem. Any suggestions?
  • Becky Terry Jun 22, 2009
    Don't understand this solution. The DVD and TV were working fine for a year. Then the problem started. How do I switch the DVD player to RGB output? Not sure what this means. Thanks!
  • Televison & ... Master
  • 5,515 Answers
I think the DVD player might either be set to output RGB, or if you are watching it via a scart to TV, and the TV is not RGB type. Alternative the TV is an RGB type and your player needs switching to RGB output.
Posted on Jun 20, 2009
  •  Grubhead
    Grubhead Jun 22, 2009
    Sorry about that, the solution only is relevant if you had just connected the DVD to the TV. Since you had it working fine before, the fault must something to do with the player or the TV. I guess you are still able to watch broadcast TV. So the DVD player is at fault. However it might be worth replacing the scart lead (if that is the way you connect it to the TV) they can go faulty from time to time and cause a green screen. If that doesn't make a difference then it could be the colour circuit has failed in the DVD, but I am not acquainted with GB players so can't help further in that department.
What causes colored stripes when playing commercial DVDs
Check your cables first to see if they are causing it. Faulty cables can cause all sorts of problems. If that doesn't solve it it could either be that the colour settings are wrong, for example NTSC instead of PAL or vice versa. Sometimes it is something to do with copy protection. In some cases counterfeit discs, or faulty discs. And in some cases a fault on the DVD player.
Oct 04, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Model LGXBR446 VCR/DVD Recorder, Have to go input on the TV to get the unit to Play, Does not play Automatically when turned on an disk or VCR inserted, Also the color is not correct
I think I know what the "skin tones blue" problem is-you probabaly have the composite video(for the old video-on-one-cord format) connected to the blue of the component video input.(component video is the red/blue green RCA type connectors).
May 31, 2012 | LG XBR446 DVD Recorder/VCR
I have a Sylvania SRD3900 DVD Player / VCR Combo that I purchased about 6 years ago. The VCR part is causing problems. When I try to play movies the picture is distorted with no sound, but it plays back...
The tracking needs to be adjusted. Sometimes it's a knob on the VCR, and sometimes it's a control on the remote. Adjust it for the best picture, and the sound shoud be restored.
Good luck, and hope this helps..
Nov 01, 2010 | Sylvania SRD3900 DVD Player/VCR
Can't figure out how to adjust VCR tracking
Open the player, use cotton wool and methylated spirit to clean the play head of your tape player and the picture will be clear. It is dirt that is making the picture shaky.
Its not all the time that tracking can solve the problem. So clean the player's play head and all will be well.
Please don't apply too much spirit and make sure you dry it with a dry wool. Also make sure the player is turned off and removed from electricity before you proceed for the cleaning.
This is the help that I can render to you.
Good luck.
Apr 23, 2010 | Quasar VHQ401 VHS VCR
Color problem
CONNECT YOUR DVD PLAYER TO SOME OTHER TV .IF THE COLORS ARE OK ,THEN YOUR TV IS AT FAULT .
THE COLORS OF YOUR TV CAN EASILY BE RE ADJUSTED BY A TV SERVICE MAN.
THE CORRECT RATIO OF RED ,GREEN ,BLUE NEEDS TO BE ADJUSTED .
Jun 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
Dvd/vcr sylvania combo
did a few google searches and suggestions were made to buy a**ther vcr...** way to fix the vcr heads. thanks anyways!
Mar 08, 2008 | Sylvania (SRDD495) DVD Player/VCR
Sony DVD player color problem
All These units need servicing, They all are having problems with the video output circuit. It could be a coupling capacitor or the video chip itself heating up and distorting the output after short playing periods.This may be a simple fix of changing the output coupling capacitors. But it also may be some internal distortion in the chip. These unit need to be tested on a oscilloscope and check out in the video out input section to look for possible component failures.You should contact a service center that will test your unit and give you an evaluation of the cost effectiveness of a repair. Hope this helps you with your problems.
Oct 29, 2007 | Polaroid 7" Two-Screen Portable DVD Player
Goldstar gbv241 dvd/vcr player
hello how you doing i have a problem with my dvd it is a goldstar GBV441 product and the problem is that on the screen it says progressive scan and i tried to do it but i coudn't do it maybe you can tell me how to do that or tell me where is the repair store for dvd
Sep 06, 2007 | Goldstar GBV241 DVD Player/VCR
GBV441 Goldstar DVD Player / VCR Combo
this is the right solution, the solution in the User Manual doesn't work
Nov 04, 2006 | Goldstar GBV241 DVD Player/VCR
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
