Question about Epson Stylus C46 InkJet Printer
Epson C46 - I want to change the black cartridge as I think its faulty but how do I change it when its still full of ink and red light isn't flashing ?
  • caz3838 Jun 20, 2009
    Hi Rina .. unfortunately I couldn't physically get the printer to move the cartridges into the right position for changing. However, I've discovered the SCC Service Utility software and one of the options allows you to do so .. so, fingers crossed !
First of all - epson sux , buy an hp or a cannon !
now , if the you tried to followthe instructions and it didn't work ,
do this : push the ink button > open the cartridge cover > grab the moving thing > and unplug the printer ....
> remover the cartridges > replug the printer !
it worked for me !
Posted on Oct 03, 2009
  • 79 Answers
You can always change without worrying about the ink levels. Be careful though, make sure that the printer is READY for cartridge removal.. good luck!
Posted on Jun 20, 2009
Replaced innk cartridges but computer says ink is
hi
clean the pins or the flat cable is in the side of cartridg and anotherone in the place that cartridg install in it
good luck
Jul 02, 2010 | Epson Stylus C46 InkJet Printer
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
Green light flashing and red light flashing alternatively. Ink cartridges appear to be full. No print
Cek status monitor ? Service required / end life? Use SSC utility to reset wate ink counter.Menu protention counter. Show cuurent value for checking. If value exceeded maximum, reset protection counter. Or Clear counter overflow.
Jun 30, 2009 | Epson Stylus C46 InkJet Printer
MY EPSON STYLUS C46 WONT ACCEPT THE BLACK INK WHICH IS NEW THIS IS THE SECOND ONE. THE RED LIGHT FLASHES AND THE GREEN LIGHT STAYS ON
Check status monitor? Black ink not recognized or what? If not recognized, red light just on. But flashes? It's may ink nearly out (low level ink) or printer need service. Check it. using SSC utilty to resolve. Reset protection counter and clear counter overflow.
Jun 27, 2009 | Epson Stylus C46 InkJet Printer
Red light flashing green light always on
One of your ink cartridge is running low on ink and you have to change it soon.If you installed the status monitor on the computer it shows which one has to be changed.
Jun 19, 2009 | Epson Stylus C46 InkJet Printer
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
Printing is not printing.
most epson printers require both inks to prints even you not gonna use it. ;)
Aug 08, 2008 | Epson Stylus C46 InkJet Printer
INK REFILL
get a new printer...this one is truly unhappy
Jul 29, 2008 | Epson Stylus C46 InkJet Printer
Flashing lights
Dear , friend
Please replace cartridge
Jul 08, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
299 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
