I found this on another website, most likely it is your power supply capacitors.
Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
my tv, when turned on via remote or manually pressing the power button on tv does not turn on. The TV power light powers on red but makes a clicking sound as if if were turning itself off after power up. (clicks on then clicks off) Humm? What could the problem be? Is there a repair part that is needed? If so. what might that be and is there a schematic or some sort of diagram to show how this issue can be resolved?
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal..
You have the dreadful blinking red light of death. Long story short the system is broken due to overheating and heat damage to the motherboard and you have a few options:
send the system to sony and receive a refurbished system for $150.
find a local to do it for much cheaper
watch vids on the web (youtube.com) and fix it yourself but it is fairly difficult.
buy a new ps3.
I hope I have helped and feel free to ask me any questions and let me know how it goes.
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
