Question about Mtd 22" Yard Machine Push Mower
I need to replace the pull cord on a 4hp, yard machine, 21",mower
Directions on how to do it?
  • 15,935 Answers
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 20, 2009
How do I replace the starter pull cord on a Yard Machine 21 inch rear bag mower
New "powermore" engine? recoil rewind starter comes as a complete assy. If the spring is broken this is your only option
Oct 28, 2012 | Yard Machines 11A54MC006 21Inch 139cc MTD...
I replaced the pull cord on an mtd mower. and now it won't rewind the cord?
You have to tension the spring before installing the cord. Remove the cord. Put the recoil assembly in a vise. Prepare the ends of the cord so they can be threaded into place. Spin the pulley in the proper direction until it is tight. Align the hole in the housing with the hole in the pulley. Thread the rope in and knot it and pull tight. Slowly let the spring tension retract the rope. Cut the rope to length, install handle, knot and test.
Gary
Aug 27, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Aug 01, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Push mower runs, starves, recovers, repeats
Sounds to be the float and needle needs replaced. The float raises the needle to let gas through the carb. If the float isn't working properly the carb starve for gas. If replacing the float, be sure to clean the carb to.
Jun 16, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Yard Machines 22'' mower, pull cord won't extend
is it flooding or is it second hand , some people cut the cord and dont fit it back properly , if it is flooding you will get hydraulic lock , answer to your question is carby service and over haul
Jun 03, 2010 | Garden
Push mower starts, then dies, ad nauseum
Guessing you have a briggs and stratton motor with a tank mounted carb.Remove the tank and carb. from the mower and replace the rubber diaphram between the carb. and tank and clean it while its off
May 09, 2010 | Mtd 22" Yard Machine Push Mower
Yard Man 21" Mower Pull Cord Won't Retract
You will find the retractable spring is broken you can go to any lawn mower shop and buy a replace me, also Wal mart and others you will have to wind it up till rope is tight then hook to the flywheel where the slot is. cost about $10.00 also lube the center hub bearing with wd 40
Jul 16, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Pull rope snapped on my Yard Machines 4hp 22in push mower
There should be 3 -3/8 or 7/16" bolts on the side of mower (where the spark plug is, there should be one) the other two will be just opposit of the two. Remove bolts and housing should be free.You might to remove any cables to free up any slack.
Jun 09, 2009 | Mtd 22" Yard Machine Push Mower
Lawn mower needs new cord to crank the engine. how do i replace the cord
Remove the 3 bolts located on the flywheel housing.(should be 7/16") one in front and two on side.
May 30, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd 22" Yard Machine Push Mower Logo
430 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
