Question about Estate TAWX700JQ Top Load Washer
Taps that connect to washer water hoses are leaking
Copper taps that lead to the washing machine water hoses (both hot and cold) are dripping from the spout even with the value closed. How do I fix this?
    Champion:
  • 225 Answers
First of all make sure water water is shut off to washer,you can take the handels off take the nut off that holds the valve in place there you find either a rubber groumet or o ring replace that put back together should fix your problem.
Posted on Jun 20, 2009
  • shane covert Jun 20, 2009
    first of all make sure water water is shut off to washer,you can take the handels off take the nut off that holds the valve in place there you find either a rubber groumet or o ring replace that put back together should fix your problem.
What does 4C mean during a wash cycle
4C Water is not supplied.
• Make sure the water taps are open.
• Make sure the water hoses are not clogged.
• Make sure the water taps are not frozen.
• Make sure the washing machine is operating with sufficient water pressure.
• Make sure that the cold water tap and the hot water tap are properly connected.
• Clean the mesh filter as it may be clogged.
NOTE
When the washer displays "4C", the washer do draining for 3 minutes. During this time, the Power button is inoperative.
Feb 11, 2018 | Washing Machines
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
I have water out of both taps when hoses are disconnected. when i connect back to taps. select cycle machine wont fill. i have turned taps fulled on with no success any ideas please... is there a reset...
(this I've pre-typed!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 08, 2011 | Washing Machines
THE SCREEN SHOWS IE
Hello there and thank you for choosing fixya
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
And finely if all of this does not work then the inlet valve on the machine needs to be replaced ok?
Hope this all helps
Aug 05, 2011 | LG WM1814CW Front Load Washer
Cold water drips in while the warm pours in,,,,, what could be the problem???
(this is general advice for overall filling problems; for 'hot or cold' read 'cold'!)
John C
Jul 14, 2011 | KitchenAid KAWS700L Top Load Washer
The machine is indicating an IE fault
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly wm_inlet_filter_removal(1).jpg
Mar 02, 2011 | LG WD-1280FHD Front Load Washer
Goes back and forth from cold to hot even when rinsing
IF UNDER WARRANTY , CALL FOR FREE SERVICE.
IF HAPPY WITH COLD WASH AND RINCE, YOU CAN
CONNECT BOTH MACINE HOSES TO A Y FITTING.
CHOOSE A GOOD QUALITY 5/8 INCH BRASS Y GARDEN HOSE FITTING.
SHUT OFF BOTH HOT AND COLD WATER TAPS.
NOW IS THE TIME TO DISCONNECT BOTH MACINE
HOSE AND CLEAN ANY DIRT IN THEIR SCREENS
OR BUY NEW GOOD QUALITY HOSES. HOSES ARE AVAILABLE WITH AN ' ANGLED' END FOR USE IN TIGHT SPACES. ALWAYS USE NEW WASHERS.
CONNECT CLEANED OR NEW HOSES TO MACHINE.
CONNECT Y 's STRAIGHT INLET TO COLD WATER TAP. CONNECT BOTH MACHINE HOSES TO THE Y
OUTLET. BE CAREFUL NOT TO TWIST HOSES.
WHEN HOSES ARE ALMOST TIGHT, TURN THEM
IN THE FITTING SO THEY ARE OK WHEN FITTINGS ARE TIGHTENED.
TURN ON COLD WATER TAP. CHECK FOR LEAKS.
YOU MAY WISH TO CONNECT A HOSE TO THE HOT WATER TAP FOR FUTURE USE. I USE AN OLD SPARE WASHING MACHINE HOSE. I ALSO CUT A FEW
INCHES OFF OF IT, FOR A SMOOTH END.
Feb 10, 2018 | Maytag MTW5600TQ Top Load Washer
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water keeps dripping after machine is turned off.
turn hot water tap off if it still drips replace cold water inlet valve if it stops replace hot water valve
Aug 14, 2009 | Maytag PAV2300 Top Load Washer
Leaking taps
Check first if leaking from hoses or under the machine.
Undo your taps, check that the hoses rubber seals haven't worn out. Replace rubber seals, most hardware plumbing sections have them. Also if the actual tap is leaking at the wall, you will have to change the tappets. You will need to close your main water at the timer, then undo the actual knobs, depending on the tap. Once opened take out tappets and replace with copper ones rather than plastic. Then put all back together and switch water on and check if leaking. In case it is the washing machine, try to replace hose or the connector on the back of machine. Make sure also all rubber seals are replaced with new ones. If under machine you will need a plumber. See how you go!
Aug 02, 2008 | Fisher and Paykel GWL11 Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
90 people viewed this question
Top Estate Washing Machines Experts
Marvin
Marvin
Justin Duby
Justin Duby
Jim Goldsmith
Jim Goldsmith
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
