Question about Alpine IVA-D300 Car DVD Player
Powers on and then turns off once you try to select the options
I have just installed the unit and it powers on and then when you select like Radio to CD it resets itself. Anyone know what could be the problem?
I just finished installing my alpine iva-d300
but it says Invalid Disc
yet no disc is inside....I hear the motor inside but it won't upload or eject the cd
Posted on Jun 28, 2009
Kenwood no sound
If you have a separate 'power' or sub-woofer amp, check that it still has power and did not blow a fuse. Is there an internal selection inside the unit for enabling the internal amp vs an external amp? Some will disable the internal amp using a setup setting, and just provide low level output that is expected to be amplified by an external amp. If it 'forgot' you might have to set it to use the internal amp again. Or vice-versa, depending.
Jul 23, 2014 | Kenwood KDC-S2009
Whirlpool duet sport
Problem: you have stopped cycle before it is done and now the unit will not start. You can press power on and select cycle but when you hit start unit powers down.
Solution: power unit on, select a cycle hit start...before the unit powers down hit pause cancel and you turn the washer off before it can turn itself off. The unit should return back to normal. This usually solves your problem without having to replace the control board.
on Dec 22, 2009 | Washing Machines
My amp blew the 20 amp fuses. Replaced and they blew as soon as the radio kicked in. Took the back off to look for any burnt connections or blown open/expanded capacitors or resistors. It smells like...
Remove all the wires from the amp including the remote turn on wire. Once you do that, after about 30 seconds the amp will reset. Hook the power up first, then the ground then the remote. Turn the unit on and check for power WITHOUT the speakers hooked up. If you get no power by now it's a good chance that the amp is cooked. If you do get power, try hoking up your speakers first on one channel then the other channel and then bridged. If it cuts out or off when you touch the speaker wires to one channel or the other, then that channel is no good. Hope this helps.
Mar 17, 2011 | Kenwood KAC-728S Car Audio Amplifier
On ps3, when switched on, says hard drive corrupted, will restore. after a while trying to restore, same thing comes up again.
  • Turn off the PS3 console, if it isn't already.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Connect your controller to the console with the USB cable when prompted to do so.Turn on the controller. You will now have access to the PS3 recovery menu.Select option three which states "Restore File System: Checks for corrupt/missing system files." This option will identify and correct and corrupt files. Your PS3 should now be fixed. If this option doesn't fix your problems, you'll want to do a complete system restore and follow the next step.Turn off the PS3 console by holding down the power button.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Select option 5 which states "Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch." Be aware that performing a complete system restore will cause all data on the hard drive to be lost. This option restores the PS3 back to its original factory condition.
  • Dec 06, 2010 | Sony Playstation 3 (PS3) Console
    Wireless speakers will not pair with the main unit
    TheSony Audio Interactive Radio Frequency (S-AIR) is a wireless digital audiotransmission signal that plays surround sound using a radio frequency that canbe placed anywhere that is convenient within the maximum communication distancewithout the signal breaking up. The system can transfer up to four channels ofCD quality (48kHz, 16 bits) audio data with no data compression.
    You have to pair the S-Airunit with the Main HTS unit. When the sound transmission is not established,the indicator of the S-AIR sub unit does turnsoff, flashes or turns Red. Please try the steps mentioned below and checkif the issue can be resolved: · Make sure that there is no other S-Air unit nearthe one which you're using. If any, place it more than 8 meters (26 1/4 feet)away from the unit. · Make sure that the units that you are trying topair are within one meter (3 feet) of each other. · Confirm that the ID of the main unit and theS-AIR sub unit are set to the same ID. · You performed pairing the main unit and anotherS-AIR sub unit. Perform the pairing steps again with the desired S-AIR subunit. · The unit is paired to another S-AIR sub unit. Cancelpairing. · Install the S-AIR main unit and S-AIR sub unitaway from other wireless products. · Stop using another wireless product long enoughto confirm if the S-AIR main unit and S-AIR sub unit gets connected. · The S-AIR sub unit is turned off. Make sure theAC power cord is connected and turn on the S-AIR sub unit. How to cancelpairing? · Perform the ID setting of the unit as follows: · Press POWER to turn the unit on. · Press the FUNCTION +/- button repeatedly untilDVD appears in the front panel display. · Press DISPLAY while the system is in the STOPmode. · Once the CONTROL MENU display appears on the TVscreen, press the up arrow or down arrow to select SETUP , and then press + . · Once the options for SETUP appears, press the uparrow or down arrow to select CUSTOM , and then press + . · Once the SETUP display appears, press the uparrow or down arrow to select AUDIO SETUP and then press + . · Once the options for AUDIO SETUP appears, pressthe up arrow or down arrow to select S-AIR SETUP , and then press + . · Press the up arrow or down arrow to select ID ,and then press + . · Press the up arrow or down arrow to select thedesired ID, and then press + . · Once you select an ID (A, B, or C), theconfirmation display appears. · Once you have selected a new ID (or evenselected the same ID as before), pairing is cancelled. NOTE: To confirm the current ID, performsteps A-G listed above. When you pair the unit with the S-AIR sub unit, PAIRINGappears beside ID on the display for selecting an ID.
    Pair the unit again and check if the issue is resolved.
    Good Luck!
    Nov 03, 2010 | Sony BRAVIA® DAV-HDX576WF Theater System...
    My Pioneer DEH-P860MP has had an issue to where it will power-up and down on it's own. Sometimes power will flash, which I can tell as the display may illuminate for a brief moment and/or the faceplate...
    you may have a bad flexible cable that goes from the face to the main pc board. there are two cables, one that goes to the upper face and another that goes to the lower fac. typically the one that goes bad is the lower.
    Oct 22, 2009 | Pioneer Premier DEH-P860MP CD Player
    JVC KD-G245 - powers up, then turns itself off after 3 seconds
    Try connecting battery and accessory wires as one instead of two seperate wires (yellow and red) had same problem and worked for me(it will not be neccesary to turn the key for the radio to work once this is done)
    Mar 05, 2009 | JVC KD-S580 CD Player
    Setting the clock
    hold source button down to turn the units power off
    once the unit is off hold down the F (function button) till you hear a beep from the unit once this has beeped press the F(function) button 2 or 3 times the clock should display flashing numbers
    once you have this press the buttons to skip the songs to the hr once hrs are set press F (function) button one more time to select minute settings after this has been set..........hold down the source button till the unit powers back on and clock will be set on this unit
    hope i was able to help you
    have a great day
    Mar 04, 2009 | Pioneer DEH-P2000 CD Player
    Amp shuts off when switched from radio to cd
    your amps rem wire is hooked to the power antenna wire on your head unit and so when you turn off the radio you would nolonger need an antenna so it powers down and would lower the antenna.Depending on the head unit you should have one output for the power antenna and one for the amp rem......If your head unit doesn't have the rem output you can wire it to the switched wire that powers your head unit but keep in mind the amp will stay on while you have the key in acc or run position even if your head unit is off.
    hope this helps!
    Jan 16, 2009 | Kenwood KAC-9152D Car Audio Amplifier
    No FM Frequency option
    I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
    Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
    Sep 24, 2007 | Delphi Roady XT XM Radio Receiver
    Alpine IVA-D300 Car DVD Player Logo
    120 people viewed this question
    Top Alpine Car Audio & Video Experts
    xxxxxx xxx
    Tygh Duval
    Tygh Duval
    Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
