Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Fan running but neither refrig or freezer is getting cold.
We have a 4 year old frigidaire refrigerator with top freecer. Fan is running but neither freezer or refrig is getting cold.
  • Frigidaire Master
  • 4,655 Answers
Your refrigerator may be stuck in defrost cycle. I know it has a defrost timer part number 215846602 Most times they are located inside the fresh food compartment behind the control panel. Sometimes below fridge and behind kick plate. The thermostat could be defective also. You can check that by unplugging the refrigerator remove cover and checking continuity between the two male connections located on the rear side of thermostat control turned as cold as you can turn it. Or you can join the two wires together and plug refrigerator back in to see if compressor comes on. When you find the defrost time turn clockwise slowly until the refrigerator starts. If these don't work let me know and we will do some more test. Sea Breeze
Posted on Jun 20, 2009
  • John Tripp
    John Tripp Jun 20, 2009
    The timer is located in the control panel inside the fresh food section. May see a small opening through plastic cover to put screwdriver inside to turn the timer. Sometimed they put a plastic plug over the hole to hide it. Please let me know if I am helping you, Thanks, Sea Breeze
  • John Tripp
    Wow, That was fast. Thank You for your Vote! Sea Breeze
    Sergeant:
  • 340 Answers
Some thing going on with the compressor
FREEZER IS TO COLD, REFRIGERATOR TO WARM
if you can; find the vent(s) between the top and, bottom boxes (where the evaporator fan is located: closing these vents makes the freezer colder and, the refrigerator warmer, opening these vents the reverse is true.
Jul 19, 2010 | Frigidaire FRT17G4B Top Freezer...
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
After emptying the ice bin on 2 year old side frigidaire, the freezer is OK, but the fresh food side has stopped cooling. Any ideas?
check that the fan in the freezer is running,it circulates the cold air,if it isclose freezer door,open refrig. door lookto the upper left you will see where the cold air enters the refrig compartment and should fill air coming thruough vent this is a motorized unit and they sometimes fail,also check the return air hole located at bottomof refrig.sometimes get blocked by plastic bags etc
Jan 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
Problems with Frigidaire FRS6R4E Side by Side Refrigerator?
The refrig side does not have a fan. only the freezer. Is that fan working??? you will hear it when the unit is running (and not in defrost) The clicking you hear is the Damper (a motorized door allowing more or less air to the refrig) opening or closing. Is there frost buildup on the back wall of the freezer??
Nov 23, 2007 | Frigidaire Side by Side Refrigerator 26...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
441 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
