Question about Elna 2007 Mechanical Sewing Machine
ELNA CLUB 500: need to replace light bulb but can't access it
I have an ELNA CLUB 500 from 1994. My light bulb went out and I need to replace it. I read the manual, which tells me to "lower socket and pull out the lamp". But when I do, the light bulb is covered by a rectangular metal case and I cannot get at the light bulb to remove it, and replace it. How can I remove the metal housing? HELP PLEASE!
SOURCE: I need to replace the light bulb on my Elna SU 62C
Switch power off first. On the top left hand side of the machine towards the front is a small hole. Insert small screwdriver in hole and push down. The light bulb will appear underneath just to the left of the presser foot. Whilst holding down the screwdriver firmly, turn bulb anti-clockwise pushing slightly upwards at the same time. Bulb should dislodge.
Posted on Mar 07, 2010
SOURCE: I have an Elna 6003Q
some call it a lamp cover door or face plate it's on the left side of the sewing machine
some sewing machines have a hinge at the back of the face plate, you can gently pull it open to change the bulb
some machines -in the middle of the face plate there is a plastic plug, use a screw driver to gently lift the plug & then unscrew the screw & change the bulb.put the face plate back on put the srew back in & put the plug back in to concile the screw
Posted on Sep 27, 2010
jyackle5
  • 8197 Answers
SOURCE: How do I oil an
For oiling the machine you need to look at the picture on the link below. The oil points are the red arrow.
Or you can get the manual on the lin kbelow page 35 will show you.
http://www.scribd.com/doc/3714472/Elna-1010-Manual
Good Luck
Posted on Nov 01, 2010
Testimonial: "Thank you."
SOURCE: new 344 elna overlocker - can't thread lower
I have been dealing with the exact same problem for 2 hours and no answers!! I have just discovered that if you move the stitch width finger to R instead of N, your threader will work!! Hope this helps :)
Posted on Nov 30, 2010
SOURCE: where would i be able to obtain a needle plate for
try these websites for the parts
sewingpartsonline.com
sewvacdoctor.com
Posted on Aug 13, 2011
Testimonial: "Thank you for the suggestions, I have already tried one but will try the other. Your prompt response was unexpected but greatly appreciated. Debbie"
Need the light bulb for the 6005 Elna. I've had this machine for many years and its been a real work horse, but now the light bulb has gone out in it.
Looking here, it looks like a capless bulb like in cars.
Lamp Socket Unit Elna 395723 43
In fact it is, a 12 volt 5 watt capless auto bulb
Changing the Light Bulb The sewing light is located behind the face plate. Unplug
the machine. Remove screw cap and screw. Pull away
face plate.
Pull out light socket. Pull out light bulb. Push in light bulb
with pins aligned to holes in light socket. Push in light
socket.
Replace face plate, screw and screw cap.
NOTE: Only use same type light bulb rated 12 Volts, 5
watts
6005 Elna light bulb Google Search
similar
ELNA 6200 Instruction Manual Changing The Light Bulb Feed Dog
Feb 05, 2018 | Sewing Machines
Elna Club 500 sewing machine manual
Try Googling (Elna)(500)(manual) without parens.
May 08, 2017 | Elna Sewing Machines
My Elna club 500 is not stitching properly. What can I do?
We need specifics of what the symptoms are. There are a lot of issues that will cause a sewing machine to not stitch properly.
Feb 20, 2017 | Elna Sewing Machines
Which is the stretch stitch on my elna club 500
Here's a copy of your owner's manual:
ELNA 500 ELECTRONIC Manual Page 16
Although it does not show a "stretch" stitch per se, there are several that can work. Machines without any stretch stitch can simply use a zig-zag.
Jun 10, 2016 | Elna Sewing Machines
How does one change the bulb on an elna 6003 sewing machine
Hopefully you have a manual that shows how to replace the bulb. Online Elna manuals have a fee.
Perhaps something here will help:
Change bulb elna 6003q
How do you change light on elna 6003 sewing machine
Watch Me For Minute Elna Lightbult Change
Jun 06, 2016 | Elna Sewing Machines
removed plastic plug (with a small screw driver,so the plastic plug
does not get damaged) on the side of the face plate
carefully removed screw behind plug--be sure not to strip the screw head
carefully pull or wiggle loose plastic cover until it comes off
giving access to bulb.
Jun 03, 2012 | Elna Quilter's Dream 6003Q
I have an Elna 6003Q sewing machine. My light bulb went out and I need to replace it. How do you get it out and replace it?
Sep 27, 2010 | Elna 2007 Mechanical Sewing Machine
Elna carina how to remove light bulb
There is a small hole on the left side of the top of the machine. Using a thin rod such as the L shaped edge guide that came with the accessories, push down in the hole and the lamp socket (which is spring loaded) will go down to allow you to grasp the bulb. Replace it with a similar long bulb available at any sewing machine repair shop.
Jan 09, 2010 | Elna Sewing Machines
Elna 2007 Mechanical Sewing Machine Logo
183 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
