I have a 10 year old Maytag washer. One the first of June I had a repair out because it would not spin and was making squealing noises when it tried to spin. He diagnosed the problem as the belt being crystalized. He replaced both belts and it seemed to have taken care of the problem. Now, 3 weeks later, it's doing the same thing again. It will not spin, there is a strong odor of rubber burning when it tries to spin. Obviously, the belt is slipping for some reason. I called the repairman again and he said the same thing about the belts had probably crystalized again. I asked him how that would be possible in just 3 weeks time when the original belts lasted 10 years. His reply was, "things aren't make as well as they used to be". We said he would order a set of belts and be out on Monday. I'm not sure I want him back if he can't fix it properly. Is it possible that there is not enough tension on the belts? He says that is controlled by the motor. I wonder too if he even used the right size belt. Please advise what you suspect and if you would find another repairman.
  • Joe Povoas May 11, 2010
    did you replace the belts yourself or the tch did it?
I called a washer repair man
Posted on Jun 21, 2009
Maytag neptune washer about 10 years old making a loud noise and leak on spin cycle
http://www.servicematters.com/maytag_library/docs/16022808.pdf
Above is your service and repair manual, download and use this manual to troubleshoot, and repair your unit.
May 17, 2010 | Washing Machines
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag washer that the agitator is not working , I makes a squealing noise, How do I repair this? Thanks
Your problem may be a seized water pump with the motor turning the drive belt on a water pump pulley that is not turning (belt squealing). Or the noise could be originating from a water pump that has a noisy/bad bearing. If the pump pulley is turning and making the noise, you may be able to lubricate the pump shaft with some quality shaft lubicant (no guarantee that the noise will cease)! If other problem, contact an appliance service company.
Feb 20, 2010 | Maytag Washing Machines
Old Maytag Dependable care washer - LAT8506
Need to replace the belt going to the transmisssion powered by the motor. these act like a clutch for the unit. It is worn out and needs replaced.
Jan 26, 2010 | Maytag Dependable Care LAT9206
My MAV8600AWW top load washer makes a loud steady squeal whining noise in spin cycle. Load size doesn't affect noise. Machine is 7 years old. Any guess as to problem?
Maytag had problems with the berrings on the transmission . water gets in and the berring goes bad rorring as it spins. Dump it and get a Whirlpool.
Nov 11, 2009 | Maytag MAV8600 Top Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
May 12, 2009 | Maytag PAV2300 Top Load Washer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
