Question about Pride Mobility Products Go-Go Elite Traveller 17AH Battery Pack
Go Go Elite Scooter - charger location problem on scooter
We need to "disable" the "it won't go" if charger is plugged into the charger port on the chair - pretty inaccessible and difficult to plug in and take out.
    New Friend:
  • 19 Answers
This is because of the inhibit circut, there is no good way to disable it, how ever one suggestion is to simply lift the battery pack off the chair and place it on a table or counter top so getting to the charger port is easier. The batteries don't have to be on the chair to charge them.
Posted on Sep 15, 2009
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
Why is the elite mega not running and shows charging and has no power?
Have you left the charger plugged in as the scooter will not power up with charger plugged into the scooter for safety reasons.
Feb 27, 2015 | Elite Health & Beauty
Scooter won't run
How old is the battery? Most are only good for three years........
Mike
Mar 15, 2014 | Ezip Currie 1000 Electric Scooter, Black
HOW DO I CHARGE A MERITS DMA SCOOTER?
With the battery charger lol I don't know if your scooter has the battery pack or not but if it does there should be a charger port located on the battery pack just plug the charger into the port and let it charge overnight. If it doesn't have the battery pack then there should be a port located on the tiller usually under the throttle levers Hope this helps
May 09, 2011 | Health & Beauty
Can you charge scooter without taking the batteries out? Is there an exterior spot to plug in?
You can charge the batteries with your offboard charger and the battery pack still on the scooter just plug the charger into the charger port on the side of the battery case and then plug it into the wall socket and charge overnite Will work just like if you removed the battery pack from the scooter. Hopw this helps you
Mar 26, 2011 | Pride Value Line Revo Scooter 3 Wheel
My scooter battery won't charge. Felt mild shock or short when attempted to insert connector. That seemed to disable the charger because the charger powers on, but will not run the charge to the...
Make sure that the charger is fully connected to the scooter; ususally the controller lights will go slowly left to right to indicate it is charging. Make sure the charger is plugged directly into the grounded wall outlet, not into an extension cord or power bar. If the charger is not being recognized by the scooter, you may need to replace the charger, or at least the power cord to the charger.
If your scooter has been sitting unused for a while? If so, the batteries might not charge anymore and will need to be replaced. Contact the manufacturer for a service call or troubleshooting over the phone.
Nov 04, 2010 | Pride Mobility Products Go-Go Elite...
I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
Charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
Jul 20, 2009 | Pride Mobility Products Go-Go Elite...
Batteries are charged, scooter won't move, no power to display
It is impossible to overcharge with the Pride charger. When the battery is full, it will stop charging and check about oncew a miute to maintain the charge.
Now, when you plug in the key (looks like an audio headset jack) does the battery meter indicate a full charge? Also, the scooter will not move if its in free wheel mode, and it will not move if the charger is plugged in. Beyond these first steps, you will need a voltage meter to troubleshoot.
Jan 18, 2009 | Pride Mobility Products Go-Go Elite...
Pride Mobility Products Go-Go Elite Traveller 17AH Battery Pack Logo
262 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
