WHAT IS THE MEANING OF THIS VSC + TRC AND ENGINE CHECK LIGHT ON WHILST MOVING
Vehicle stability control and traction control work together so if one turns on the other usually turns on at the same time, the fact the engine light turned on as well makes me think it could be a voltage issue. possibly weak battery. tsc and trc are very sensitive to voltage changes and so are emission control on the engine. so in theory the low voltage would cause all three light to turn on. a generic drb2 would be able to scan the engine light code, so if it has anything pertaining to voltage I am sure that would be your problem
SOURCE: Check Engine Light
If the light isn't flashing, it is safe to drive. If it is flashing, then catalytic converter damage can result. Have a parts store check the codes for you and come back and post the code.
SOURCE: check engine light on and code po108
PO108 (map circuit high input) MAP is manifold absolute pressure... a sensor normally mounted on the intake. your code is suggesting a problem with this sensor, or its circuitry.
SOURCE: 2001 Dodge Caravan/check engine light
Is your gas cap tight? check it, these codes indicate a large leak in the fuel evaporative emission recovery system at the gas tank
SOURCE: "Check Engine light"
The issue is that the system randomly checks the loop of the fuel system to confirm that it has no leaks. A missing cap is the easy one to correct. It might also be a slpit in the rubber hose that connects the fuel fill tube (on the chassis) to the one on the tank, or any other hose in the the entire fuel delivery/ fume recovery sysrtem. The solenoid that allows the engine's vacuum to be used to conduct this test can also be sticking so that after the test cycle, it doesn't reclose. Good luck
SOURCE: Three problems so far. Check engine light stays
You might try removing the battery connectors for five minutes and replacing back.
If the codes do not disappear, please you might have to get a scanner to do that.
Cheers.
