Question about KitchenAid Kitchen Ranges
I have a kitchenaid professional 600 and I'm having a problem taking it apart to grease the gears. I can't seem to figure out a way to remove the retaining clips that are on the arm that holds attachments.
  • edric929 Jun 21, 2009
    the c-clip in the video looks like it has an opening of 1/4 inch or so. The C-Clip on the kitchen aid has about 1/16 - 1/32 inch opening in it. It doesn't look like the right tool. The clip does have 2 pin holes on either side of the opening.
  • 547 Answers
There is a tool you can pick up at any hard ware store for the clamps you are talking about you can also try neddle nosed pliers and push from both sides of the clip to remove but your best bet is to go buy the tool as it sounds like you will be doing this process again . Thank You For Using Fixya
Posted on Jun 21, 2009
    Genius:
  • 1,689 Answers
Those are C-clips.
you can remove them like the one in the video below.
http://www.youtube.com/watch?v=Bry5G5AVb58
regards,
voodoo
Posted on Jun 20, 2009
I need to replace the Beveled Gear for my Pro 600 mixer. it seemed an easy task. However, I am stuck in removing the Beveled gear. I cannot remove it after removing the retaining ring. help pls.
If you have the gear cases apart and the bevel gear exposed then you just push the planetary shaft up through the middle of the bevel gear. You will see that the shaft is driven by the gear via a loose fitting pin through the shaft. Pull the pin out (with fingers) and then the bevel gear will lift up off the shaft without the need to fully remove the shaft. Note the fibre spacer/thrust washer under the bevel gear between the bottom case and gear, don't lose it.
Aug 08, 2016 | KitchenAid Professional 600 6 Qt. Stand...
Grinding Sound
It could be a different gear that is stripped in the mixer. There is also the chance that the gear that was sent you was damaged before it was put in, we do see chipped gears come from KitchenAid every once in a while. The best thing to do would be to take apart the mixer, clean the grease off the gears, and carefully inspect each one for chips or gouges in the gears.
Jan 23, 2014 | KitchenAid ProLine 600 Stand Mixer
Motor clicks every turn
The clicking is probably a small nick in one of the gears, even the smallest chip can cause alot of noise or make the mixer click. Is the beater shaft still turning when you have a load in the mixer (bowl is full)
Or is it just clicking?
If the beater stops turning it is going to be caused by stripped gears, however if it is just clicking this would indicate just a nick in the gear. Either way I would recommend opening the mixer and replacing the damaged gear/gears.
Your mixer is considered a 5 Quart Professional, which means it has the same parts as a KitchenAid 6 quart mixer. The first thing you will want to do is take the mixer apart and disassemble the gearing. You will want to clean off the gears with paper towels and wd-40. Carefully inspect each gear once clean and replace damaged gears.
In the professional mixers when a gear strips you need to replace the grease and housing gasket, this is because the gears are all metal and there may be metal shavings in the grease which could cause the gears to strip again.
The most common gear to go bad in the Professional series mixers is the Worm Follower Gear (9706529). Here is a link to that gear on our website: http://www.mendingshed.com/wormfollower.html
Also, here is a link to the service manual for the mixer, this will aid you in taking the mixer apart and putting it back together correctly. http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
We are one of KitchenAid's largest service centers within the US, and all parts we sell are genuine KitchenAid products. All parts are available at our website, www.mendingshed.com
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 06, 2013 | KitchenAid New Professional 5.5 QT...
KitchenAid stops working when anything other than liquid is in the bowl..
There is a non metal gear inside the motor head that is stripped and no longer engaging the worm drive. What happens when you try to assist the turning process (try it only on stir speed, sloooowwwww) if it starts to turn and then stops again then it is the gear I spoke of. It will require tearing down the machine, cleaning all old grease, to insure that you have no ground up parts in the grease, then replace the grease gasket and gear. Hope this helps
Jan 11, 2013 | KitchenAid Professional 600 Series 6-Quart...
KitchenAid Mixer Gears Slipping
Take it to a local small appliance repair business and get and estimate.
Jul 07, 2017 | KitchenAid Food Mixers
Ticking sound in kitcheaid mixer
Remove the planetary and see if the noise vanishes, if not then you will need to open up the gearbox. It could be the pin retaining the fuse gear or maybe even the fuse gear itself failing. It seems unlikely though as you were only whipping cream and there is no effort in that.
Sep 03, 2012 | KitchenAid Professional 600 6 Qt. Stand...
Kitchenaid mixer leaking oil
Get a copy of the Repair Part List for your model at Kitchenaid.com
Grease inside the Planetary Assembly (the shaft is tight fit to the Planetary
plate at the factory and is not designed to be taken apart, so do not use
any hard object such as a screwdriver to separate them) over times can
turn to liquid and leak down the bowl. Removing the Planetary assembly
and adding Kitchenaid Food Grade Grease is not a task for a novice.
To properly remove the Planetary Assembly, you must work from inside
the Transmission Housing: Remove in this order: Retaining Clip(25), Bevel Gear(21),
Retaining Pin(18), Worm Follower Gear(19). Use a soft mallet to tap out the Shaft
of the Planetary Assembly(15). Re-assemble it in the reverse order.
Note: The Bevel Gear is extremely tightly fit on the shaft, and a pin punch
must be used to remove from the shaft.
Jul 14, 2011 | KitchenAid KP2671 Professional 6 Series...
I have a KitchenAid Professional 600 Series 6-Quart Stand Mixer, model KP26M1XBS, which no longer works. I was mixing pretzel dough and the mixer stopped turning. I initially just thought it overheated...
Don't worry about the Worm Gear for now. You have to make sure that the Motor
is fully functional by itself: Remove the Transmission Housing Cover (4 screws) and
the two screws holding the Motor down. Lift the Motor off the Worm Gear and set it
on the side (be careful of AC voltages from the Motor and Control Assembly).
Select Stir setting and observe the motor shaft. Is the Motor running? If it is,
Select other speeds to see how the motor performs.
With the motor now fully functional, you can now check the Worm Gear Follower
for worn out/broken teeth. Remember the motor drives the Worm Gear, it then in
turn drives the Worm Gear Follower (you may have to remove the grease to see it)
The Bevel Gear sits right on top of the Follower and drives the Attachment Gear.
Jul 06, 2011 | KitchenAid Food Mixers
KitchenAid 600, Stand Mixer - Loud grinding noise, happened when mixing bread dough. When bowl is lowered (dough hook disengaged)....no noise, hook turns. When bowl is raised so that hook engages dough,...
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Jan 31, 2009 | KitchenAid KP2671 Professional 6 Series...
Kitchen Ranges Logo
46 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
