SOURCE: DELL 1000 INSPIRON CMOS BATTERY
Should be one of two places on the Dells. Look under the memory cover, if not under the keyboard. If you still can't find it, go to Dell's support site and pull a system diagram. If you haven't already, it's very helpful to know what the bat looks like. Dell uses a few different types.
SOURCE: where is the location of cmos battery on dell 2650.
pulling the battery will not help it is hard coded in CMOS you need to send it in or take it to a service center that can re flash it for you i do not suggest you re flash BIOS on your own because that could cause a bigger problem
SOURCE: Dell Inspiron 1000 notebook - where is the CMOS battery located
underneath the keyboard, pull the top plastic line cover (the one covering the power button) then two screws and pull it off carefully, the ribbon connection will pull out pretty easy but be carefull not to twist it.
SOURCE: dell 5100 cmos battery replacement
The CMOS battery most likely is a button battery, probably a CR2032 lithium battery. The battery could be located on the bottom of the laptop behind one of the panels or under the keyboard. There is no MOP, when you remove the battery it may default to the factory defaults (depends how long the battery has been removed) and you need to go into the BIOS setting to set the Date and Time etc.
SOURCE: Dell C610 battery cmos/bios
The removal and replacement instructions can be found in the dell service documents available at support.dell.com. You can look it up by service tag or model number. But in short, the procedures are. 1. Remove the hard drive, then remove the keyboard. The keyboard is removed by removing the 5 screws on the bottom of the laptop marked with a "K" beside them. Then the keyboard can be removed. be careful not to tear the ribbon cable, and you do not have to remove the ribbon cable. The battery will be in the center of the opening, it will have a white plug that plugs into the keyboard. Contrary to Ayyasam's recomendations above, it is not necessary to remove "all" the screws on the bottom, nor is it necessary to remove the bottom of the laptop. It should be a 5 minute project. Again for any Dell item, the factory repair manuals are available online, and have exact instructions including pictures and diagrams.
Happy Computing
Daver56
